Question about Kenmore 63792 Microwave Oven
Turn table doesn't turn
Kenmore microwave turn table only turns with the turn table removed...I can see the thing it sits on turning
    President:
  • 3,433 Answers
Is the plate engaging the drive?
Posted on Jun 15, 2009
My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
https://www.searspartsdirect.com/part-number/241700104/0046/253.html?pathTaken=partSearch&q=241700104
Jan 13, 2018 | Microwave Ovens
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
Fix a kenmore microwave turn table model 721.80012401will not turn
http://www.ebay.co.uk/sch/i.html?_odkw=kenmore+microwave&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xkenmore+microwave+motor&_nkw=kenmore+microwave+motor&_sacat=0
Aug 11, 2014 | Kenmore Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Microwave turntable.
Is that the only thing that doesn't work? If so it could be a coupler or a belt, possibly the motor it self.
Sep 17, 2009 | Kenmore 63252 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Kenmore 63792 Microwave Oven Logo
179 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
