Question about Samsung UN55B8000 55 in. LCD HDTV
WHERE IS POWER BOARD FOUND IN THE UN55B8000
WHERE IS THE POWER BOARD LOCATED ON A SAMSUNG UN55B8000
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
Samsung UN55B8000XFXZA not powering on
Most likely your power supply is defective. I would suggest you check the fuse on the power board. If it is blown, you have a problem with the power supply
Apr 15, 2013 | Samsung UN55B8000 55 in. LCD HDTV
Led 55 in 3d samsung 240 hz smart tv keeps freezing
FIXED!!..I had the same problem. Power board looked fine (not blown capacitors) It started after a moving...it was just faulty (loose) connectors from the powerboard to the mainboard..... I just unplugged and plugged them back firmly. db2f651f-d050-4b58-b50a-79ef9a8650f9.jpg
Feb 19, 2013 | Samsung UN55B8000 55 in. LCD HDTV
Turn on
Three thoughts---check for short to ground with fuse removed and power off (unplugged) on both sides of fuse.
Use a original type fuse---generic ones often blow for no reason.
Consider replacing the board if you can confirm issue is on it.
Nov 03, 2012 | Samsung UN55B8000 55 in. LCD HDTV
Tv will not power up
First if you are able is to examine the power board---look for any signs of damage or puffed up filter caps..........
Aug 31, 2012 | Samsung UN55B8000 55 in. LCD HDTV
I have the samsung 55 in lcd tv with the double vision ...i see the picture on the home page and it is exactly like the picture...how much will this cost me..i bought my tv back in aug of 2009...
If all pictures including the menus appear in double than most likely your T-con board or T-concable are defective. The T-con is located on the upper portion of the rear of the LCD panel itself. Here is a link where the board and the cable can be purchased. Note there are a few different versions of the T-con board and they wil not cross with each other. There is a bar code on the T-con board with numbers that corralate with the correct part number. Follow that before ordereing : )
http://www.shopjimmy.com/catalogsearch/result/?q=UN55B8000
Jul 25, 2011 | Samsung UN55B8000 55 in. LCD HDTV
Turn off and on codes
samsung usually doesnt have a code. hide a switched power strip or something behind the tv or unhook it somehow when you're away. you can lock cableboxes and sat boxes sometimes, but i think that panasonic code is a rare thing
Jun 17, 2010 | Samsung UN55B8000 55 in. LCD HDTV
Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Apr 13, 2010 | Samsung UN55B8000 55 in. LCD HDTV
Tv won't turn on; when plugged in just makes a clicking sound
It should be problem with Power supply of LCD TV Replaced New Board of same part number.
Jan 14, 2010 | Samsung UN55B8000 55 in. LCD HDTV
Samsung UN55B8000 55 in. LCD HDTV Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
