Question about Panasonic TC-26LX20 26 in. HD-Ready LCD Television
Toshiba tv 46sl412u turns on black and no sound
Toshiba tv 46sl412u turn on, no picture or sound
Toshiba 46SL412U lines on screen
Those look like dead pixels. If there has been any impact to the screens surface recently, you can attribute them to that. If you want it fixed, is suggest that you'd be better off getting a new screen.
Oct 14, 2016 | Toshiba 46SL412U 46 in. TV
I have a Toshiba 50L2300U TV which has sound, but the screen is black. I believe it's because the backlight inverter is not functioning. What part needs to be replaced?
Hi Anonymous, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=WtRuUBS9doE
Toshiba 55HT1U repair No Picture
May 05, 2016 | Toshiba 50L2300U
Toshiba screen black
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
May 31, 2014 | Toshiba 46SL412U 46 in. TV
TV Toshiba flat screen
You hv bad capacetor on power board. Just open back of your tv and you will see couple capcetor swelen. They are only couple of dollar each. You just need to know to soder them
Jul 05, 2012 | Toshiba 46SL412U 46 Class Widescreen LED...
Last month we bought a new Toshiba 46SL412U LED TV. We would like to hook up our digital camera to it to see pictures of a recent vacation. We don't know how to do it. All that came with the TV was...
Your television has a USB port. Yyou can hook up your camera to the tv using a USB cable, goto input ->USB select pictures as the type of content to browse the pictures on the tv.
Jul 15, 2011 | Toshiba Televison & Video
Toshiba 40xf355d 40inch Plasma tv won't turn on it just makes a clicking noise. thez no picture or sound? my tv powers on and makes a clickin sound but i dont get picture or sound its stays black i have...
That model is an LCD that uses a backlight. Probably with CCFL tubes. They are known to have bad inverter supplies. Its an old TV though. Keep that in mind.
Jan 05, 2018 | Toshiba Televison & Video
Toshiba 37XV503DB FAULT NO PICTURE
Have the exact same TV and had the same thing happen a couple hours ago.
Apr 04, 2010 | Toshiba Televison & Video
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Panasonic TC-26LX20 26 in. HD-Ready LCD Television Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
