Steps from manual on how to do stemp plot box
To make a plot, first you will need to define a list. To do this, press "{", then enter the values of your list, separating each value with a comma, and ending the list with "}" then store (STO>) the list into a list variable ("2nd" + "1", "2", etc.). For a box plot, you will need only one list, and for a scatter plot, you will need two. One for the independent variable, and one for the response variable; that is, one for the X and Y axis, respectively. To make your plot, open the plot menu ("2nd" + "Y=") and select a plot. From there, you may select the type of plot and which lists to use as values.
To find the residuals for the line of best fit, from the home screen, press "STAT", then move one right to "CALC", then select option 4, "LinReg(ax+b)". Once this command is on your home screen, follow it with your X and Y axis lists, separated by a comma, eg: "LinReg(ax+b) L1, L2". Press enter. In a moment, you will be provided with 'a' and 'b' values. Plug those residuals into your "Y=" menu in the form "ax+b", replacing 'a' and 'b' with the residuals, and the line of best fit will be drawn across your graph.
