Question about netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service
Will not connect caller is informed wireless customer not available
Message states UT03ML
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
Tip
Connect PS3 to the Internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
on Feb 20, 2010 | Video Game Consoles & Games
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
Hi kdfrance
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Hope this info was helpful cheers nikki
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Hi kdfrance
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
I cant connect to the internet
Playstation 3: How to setup your Internet connection This article helps you in setting up the Internet connection for Playstation 3 To enjoy the online capability of Playstation 3, you need to connect it to the internet. You can do it in two ways:
  1. Wired Connectivity.
  2. Wireless Connectivity.
Wired Connectivity:
  • A cable modem
Back to top
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your provider
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Can u please help me connect my ps3 to play games online i have usb modem connected to laptop, with ethernet cable connected to ps3 from laptop......... i live in australia
Wired Connectivity:
  • A cable modem
Back to top
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My xbox is saying error e74
CAUSE This problem occurs when the Xbox 360 console experiences a general hardware failure.uparrow.gifBack to the top
MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section. To confirm your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.uparrow.gifBack to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: United States Customers
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Outside the United States http://www.xbox.com/support/ Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 10, 2010 | Microsoft Xbox Console
Two Questions Connecting with Belkin Wireless Router...
To answer the first question, please provide what kind of operating system you are using, and please provide the exact error message. Its probably just a caution/nag that you don't really have to worry about, but if you provide more information then so can we.
For the second question, you will need to setup the WEP on the laptop to get the laptop to connect to the router via wireless, regardless if it was used to setup the router, the wireless network is encrypted so it will need to be accessed by a computer(s) that have the key programmed into them. You can plug in the laptop into the hardwire Ethernet port for configuration, that is another option.
May 14, 2008 | Belkin (F5D7231-4) Wireless Router
Coller ID Inoperative
Here is the tip directly from the manufacture vtech. Tip 1 of 1 Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information. In addition, your caller must be calling from an area that supports caller ID. Both you and your caller?s telephone service provider must use compatible caller ID systems. Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller?s service, transmission errors and answering calls before the ID data is received. They state that if you have further problems, to contact customer support at 1-800-595-9511. Also, who is your phone service provider? And who is the manufacture of the old phone? If this does not help, please post further. Also, please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Vtech ia5854 Cordless Phone
netTALK DUO Wi-Fi VOIP Internet Phone Device With 12 Months Service Logo
82 people viewed this question
Top netTALK Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a netTALK Cell Phone Expert? Answer questions, earn points and help others
