Question about Disney Brother Bear for Windows
Cannot run brother bear in windows 7
Brother bear won't install in windows 7
Brother printer file wont install
Try to run in a different capatability mode like xp
Aug 19, 2013 | Sony VAIO Computers & Internet
My Brother HL-2070N printer won't print Web page
In January 2011 Brother update its drivers for your printer due to a compatibility problem. You haven't advised what operating system you're using but you apparently need to update your drivers.
If you are running Windows 7, you will have to update the drivers either from Microsoft Update or Brother. Click on this link for Brother.
If you are running Windows XP, CLICK HERE
Apr 23, 2012 | Brother HL-2070N Laser Printer
I have a 210C and it won't work with my new Windows 7?
Use the Windows Update to install your MFC 210C AIO printer drivers.
Refer to this link @ http://www.brother-usa.com/lp/windows7compatibility.aspx#WinUpdate
Hope it helps.
Aug 12, 2011 | Brother MFC 420CN All-In-One InkJet...
How can I run my old copy of Monopoly from Infogrames on Windows 7?
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
Feb 13, 2011 | Infogrames Monopoly 3 for Windows
Just got a new computer w/windows 7 and now my brother mfc-8840D won't scan to pdf now? Any ideas on a solution to fix?
How to get a MFC-8840/D/DN to scan to Windows 7 over the network or by USB:
First - Download the Windows Vista Full Driver & Software Package from Brother: Brother MFC-8840DN driver download page
Install the drivers using a custom install - pick only the Network scanning drivers, unless you want the other junk - no promises on how well the other stuff works.
Alternatively, if connecting the MFC-8840DN to Windows 7 by USB, download the Printer and Scanner Driver for Local Connection. It is a separate download. Install only the Scanner driver.
Once the Vista scanner driver is installed, you can test by running the built-in Windows 7 Scanner Wizard. Here are instructions on how to test.
As far as conversion to PDF, that will depend on the software. I am not sure if the Control Center or Paperport softwares work on Windows 7. I have not tried those. I have found that freeware STP will works fine.
Here is a link to the STP homepage.
Here is a link to how to use STP with the Brother MFC-8840DN
May 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
I want to install my brother MFC-5840CN onto a new laptop that is running windows 7. It will not install from the disc and says to visit the brother solution centre that does not give me any help. How can...
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_top.html?reg=eu&c=gb〈=en∏=mfc5840cn_all
Click driver, then the windows that is closest to windows 7 (Vista) 32 or 64 bit, depending on what windows7 you have installed. Vista is very close to Win7 so a vista driver may well work.
So select Driver, then Windows Vista in the box below (or Windows Vista x64 Edition) depending on your current bit, then select English and then search.
On the next page click to download the Full Driver & Software Package.
This may well help you, and the drivers here will be much newer then whats on your disc, as will be the utilities.
Hope this helps you.
Jan 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
I cannot install brother mfc 210c in windows 7
Go to www.brother.com drill down in the support/driver/downloads section. Look for/download avail. drivers for Windows 7 for that device (when Win7 is publicly avail.)
gurutim
Mar 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Disney  Brother Bear for Windows Logo
27 people viewed this question
Top Disney Video Game Consoles & Games Experts
James Wishart
ptpumpman
Are you a Disney Video Game Console and Game Expert? Answer questions, earn points and help others
