Question about Disney DTD1363-CAR 13" TV/DVD
Wont come on
The tv will not come on i hooked up the cable to it
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
Trying to hook tv up outside of house ran cable from box in my house wont run my tv outside can I buy hdmi ******* and have it work ? Thanks
I'm hoping you hooked the cable you ran for the outside tv to the output of the cable box and didn't make the mistake of splitting the cable that comes into the satellite box. If you take the cable that goes to your TV inside you should be able to put a splitter in it and run the TV inside as well as the one outside. If it is a long distance to the outside TV you may want to buy a powered splitter that amplifies the signal. You should also be using RG6 coaxial cable to cut down on lose.
Sep 22, 2014 | Audiovox Directv Rca Drd430rg Receiver...
I have just hooked up set top box to Sharp TV CX5182 and need to re-tune it? Can you send me instructions please as I can't find my operators manual. Many thanks.
By set top box do you mean a digital tuner box? If so and your tv is a newer flat panal than more than likely you wont need it anymore. That tuner will be built in. If this is the case than hook your anntena up to the new tv and go to the menu to do an auto channel search. That should do the trick. If it is an older tv and doesnt have the tuner then hook up the box the way you hooked it up before IE if you used cable than hook it up with cable if you used it with Composite cables(RCA) than use those the reason is some of those boxes you have to set that part up in the settings and that disabled the other output so if you had it set for cable than hooked it up with Composite(rca) nada, nothing would show. Once you hook it up and you see it on the screen then your good to go simple channel search from there. Also if you use cable then your tv needs to be on channel 3 or 4 if you use Composite(rca yellow red and white) then your tv has to be on the input channel that coencides with what input is hooked to.
Dec 13, 2010 | Televison & Video
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
Hooking up dvd player to tv
try to change tv video format from PAL to NTSC then vice versa.
Jul 10, 2009 | Televison & Video
Disney DTD1363-CAR 13" TV/DVD Logo
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
