Question about Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii
Read codes 02 Sensor Unit Bank 1 Sensor 1
Error code P0134 on 2004 mitsubishi Galant
Possible causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
alt="Help with Possible causes"> What does this mean? Tech notes
Replacing the Front Heated Oxygen Sensor Bank 1 usually takes care of the problem
Sep 01, 2014 | 2004 Mitsubishi Galant
My 96 nissian maxima turns off when driving down the road i try to turn the key ,lights in dash on horn blows but will not startcould it be alternater ,or what how does the 02 sensor go by functioning ...
As of 1996,all cars sold in the US were required to have an OBD-II computer interface port.
You may want to go to Advance Auto Parts, AutoZone, or Pep Boys, and get a free read
of the code(s) that you computer may be posting to help with your diagnosis.
The code coming from your vehicle's computer may be one or more of:
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
P0300 - Random/Multiple Cylinder misfire detected
P0301 - Cylinder 1 misfire detected
P0302 - Cylinder 2 misfire detected
P0303 - Cylinder 3 misfire detected
P0304 - Cylinder 4 misfire detected
P0305 - Cylinder 5 misfire detected
P0306 - Cylinder 6 misfire detected
P0307 - Cylinder 7 misfire detected
P0308 - Cylinder 8 misfire detected
P0313 - Misfire detected with low fuel
Maximas with the VE30DE and VQ30DE engines use a distributorless ignition system that is controlled by the Engine Control Module (ECM). The ECM receives a signal from the crankshaft sensor (the CPS - Crankshaft Position Sensor), and processes the signal based on inputs
from other various engine sensors, including the Oxygen sensor.
(this is the role of the O2 sensor in ECM operation).
Then the ECM sends signals to each of the individual coils in the proper firing order.
This system is more efficient than a distributor, and has fewer moving parts. The high voltage coils are directly attached to each spark plug, allowing a higher energy spark within the cylinder. A high energy spark means a faster, more thorough burning of the air/fuel mixture, which produces more power and lower emissions.
SECONDARY SPARK TEST - works for all cars, including Maxima.
1. Remove the spark plug.
2. Install the spark plug to the ignition coil/coil pack, then attach the coil wiring.
3. Ground the plug at a good ground location on the engine.
4. Crank the engine and check for spark.
5. If spark occurs, the ignition system is functioning properly.
6. If no spark exists, test the ignition coil/coil pack, power transistor and related wiring.
HEI Ignition Spark test - works for all cars, including Maxima.
The next level test you may want to try is a HEI (high energy ignition) spark tester kit. Cost is
about $30 at most auto parts stores. Harbor Freight Tools sells a chinese equivalent for about $16.
Place the spark tester on each of the spark plugs, and watch as the little light in the tester will
light up each time the spark plug is fired by the computer. You can actually see weak or
intermittent sparking as the motor runs - you can tell by the relative strength of the light as
you compare the intensity and duration of the light across all 6 cylinders.
If your problem were the alternator (or its built-in voltage regulator), your battery would not be
getting a proper charge, and you
wouldn't be able to start the car after a drive, since the battery would have been drained during the
drive - normally, the alternator will both charge the battery and run all electrical
features of the car during a drive.
To test your alternator, place your DMM (digital multimeter) across the battery terminals while the
car is running - it should read 13.5VDC to 14.5VDC. With the car off, you can test your battery
voltage with the same DMM - it should read 12.65 VDC (for a fully charged battery).
Alternatively, you can take your car to Advance Auto Parts, AutoZone, or Pep Boys, and they'll
attach their "charging system tester" to your car and give your car a nice test for free.
I do this with my customers' cars just to get that nifty printout of the problem. Its nice
to show a vehicle owner somethng in black & white when I'm recommending a new charging
or ignition system component (some of which can be a bit pricey).
Jul 15, 2011 | 1996 Nissan Maxima
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
Jul 03, 2011 | 2004 Saturn VUE
Error codes po 134 po 153 po 154 po 155 po 171 po 174
PO 134 = 02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 1 SENSOR1)
PO 153 =02 SENSOR CIRCUIT SLOW RESPONSE (BANK 2 SENSOR 1)
PO 154 =02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 2 SENSOR 1)
PO 155= 02 SENSOR HEATER CIRCUIT MALFUNCTION (BANK 2 SENSOR 1)
PO 171= SYSTEM TOO LEAN (BANK 1)
PO 174= SYSTEM TOO LEAN (BANK 2)
I WOULD SAY YOU HAVE FAULTY OXYGEN SENSORS CAUSING THE ENGINE TO RUN TOO LEAN REPLACE THEM AND YOU SHOULD BE BACK IN BUISNESS
Feb 23, 2011 | 2004 Suzuki Grand Vitara
The service engine soon lite came on on my 02 Sierra Denali truck. Had a check completed and code P0135 (bank 1 sensor 1) came up. Did a bit of research to see which O2 sensor may be causing the problem....
if i am not mistaken , bank 1 is the closest 02 sensor to the engine, look down onto your exhaust system , and follow it to the closest 02 sensor to the engine. and check the wire connection to it to make sure it is not frayed or disconnected.
Feb 18, 2011 | GMC Sierra Cars & Trucks
What do the codes 1128, 1129, 1133, and 1134 mean on my Porsche Boxter 2001?
code P1128 02 sensor bank 1 lean
code P1129 02 sensor bank 1 lean to limit
code P1133 02 sensor bank 2 lean
code P1134 02 sensor bank 2 lean to limit
fuel system is lean.
Jan 29, 2011 | 2001 Porsche Boxster
I have a 2000 Hyundai Sonata that runs rough when you start it up. I hooked a code reader to it and it said that system was lean on bank 1 and multi misfire and not reading 02 sensor on bank one. I have...
time to get the engine properly scanned, real time not code scanner, then you will have the readings from sensore and actuators, diagnose from there
Dec 14, 2010 | Hyundai Motor 2004 Sonata
Engine computer reads code 133 and 137......need to know what it means. I have a 2002 daewoo laos
ok this one is simple code ( 133 ) is ( 02 sensor circuit slow response) ( bank 1 sensor 1) and code ( 137 ) is ( 02 sensor low voltage ) ( bank 1 sensor 2 )
Sep 15, 2010 | 2001 Daewoo Lanos
Code P0157 and P0137
Hi P0157 is
02 sensor circuit low voltage bank 2 sensor 1
P0137
02 sensor circuit low voltage bank 1 sensor 2
May 06, 2009 | 2000 GMC New Sierra 1500
Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii Logo
Top Autel Computers & Internet Experts
David Payne
David Payne
Are you an Autel Computer and Internet Expert? Answer questions, earn points and help others
