Question about Xerox Office Equipment & Supplies
Xerox work center 7125 copier & printer manual
SOURCE: Xerox WorkCentre XE88 copier
Black line usually caused by cleaning blade failure or drum damage
If the fault only occurs when using document feeder and not off the glass, clean the scanner glass (the narrow strip at the side of main glass if fitted)
Drum /cleaning blades are usually contained in the "throw-away" cartridge It would be nice if you could find someone with same machine you could try a swap to prove it
Posted on Nov 16, 2007
SOURCE: Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
Posted on Nov 23, 2008
SOURCE: i have xerox works center pro photo copier model
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
Posted on Dec 30, 2009
SOURCE: xerox color copier. model dc12 printer/copier error code 14-372.
error 9-lexmark2350
Posted on Apr 13, 2010
SOURCE: What does Error Code
That is a problem with the polygon mirror motor. That is the motor that rotates the missors in the laser assembly.
Most likely have to replace the laser.
Google a business called The Parts Drop.
Give them a call and ask for Britt. He will help you.
I believe there are 2 different lasers for that machine. I am not sure just the mirror motor is spared.
Here I pulled up the site and phone number. I have ordered from them for years. Top knotch people to do business with.
Posted on Aug 02, 2010
Aug 02, 2016 | Xerox WorkCentre 3119 Laser Printer
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
Sep 16, 2013 | Xerox WorkCentre 7120 7125 Waste Toner...
May 26, 2011 | Xerox WorkCentre M-24 Color Copier
Jan 03, 2011 | Xerox WorkCenter 4150 Black and White...
Nov 10, 2010 | Xerox DocuColor 3535 Copier
Aug 19, 2010 | Xerox DocuColor 12 Printer
Aug 15, 2008 | Xerox DocuColor 12 Printer
Jul 18, 2008 | Office Equipment & Supplies
