Question about LeadSinger Audio Players & Recorders
No power on mic
Haven't used in a while and there is no power on the mic when I plug in. what could be wrong and how can I fix
I noticed today that my Rode mic didn't produce any sound at all. It has been on a mic stand for a couple of weeks at my home. I read that moisture can be one reason why the mic doesn't work. I...
The whole situation that you describe makes me believe that the Rode mic is ok. Please double check your cables, the connections and the settings at the mixer that you connect the Rode. Also make sure that the phantom power supply is enabled.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 10, 2011 | Rode NT1A Professional Microphone
Very low volume from mic input even with Gain and Master turned full on
You haven't told us what type mic you are using. If you are trying to use a condensr mic with this, you will need a preamp that supplies Phantom power to the mic. You haven't told us what cable you are using. Do check that you aren't using a condenser mic as there will be virtually no volume.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
I have a 18 WX ST Cobra CB Radio and when I turn it on, it hums constantly, . Then when I unplug the microphone, it stops. When I plug it back in , it starts again. Any ideas why it does this?
Sounds like the mic plug or inlet is bad,could be a bad mic or plug wired wrong.Try, if you can,a different mic that you know works for your model,if this also fails,a qualified tech is going to be needed to repair.I will suggest one thing you can try,if your confident enough, is where the mic plug goes into the radio there are four or five pins,look closely at the pins and you will see they have slots on the top of them, with the radio power disconnected,not just turned off,try spreading the slots open slightly with a precision slotted screwdriver or small object that will accomplish this,don't use a wood toothpick,it could break off in the pin.Now plug the mic in and tighten it down,reconnect power and see if this solves problem..Good luck
Aug 19, 2011 | Cobra Radio Communications
I have a fujifilm digital camera its a finepixv10 i plugged the wrong charger into it now it will not turn on , can you help ?
As you have used wrong charger so you have to see if the problem is withe the camera or FUJIFILM FinePix V10 Zoom battery, Or if the battery haven't been charged by the charger, so the power is empty and you can't turn on camera, Then use a right FinePix V10 Zoom battery charger..
Apr 26, 2011 | Cameras
I can hear music but I can't speak using the microphone
You should check to see if the mic is plug into the right port and then try to using it,because if it is in the wrong port it will not work.You should also make the mic is plug in properly if the problem still exist this mean the mic is bad.
Aug 17, 2010 | Computers & Internet
My mic does not work. when i looked inside computer i notice that a plug that was labled mic power [yellow wire] was not plugged in. I power cleaned the inside with a air compressor and might have jarred...
Desktop PC's do NOT come with any Mic's attached, they only use a Mic, Jack usually Red. You can plug a Mic, into this and use it that way. Also you can get a USB Mic, or headset, this is usually what is done. That Mic. Power, & it supplies power to a thing called an "Electret Mic" I have found a link below.so you can find your manual http://www.foxconnchannel.com/support/downloads.aspx
Mar 05, 2010 | Computers & Internet
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Realistic Cardioid Dynamic mic (33-992A) mic plug wiring
i think you would save time buy just buying a usb mircophone
ive seen them getting very low in price. you risk damaging your computer if you get the wiring wrong.
Feb 22, 2009 | Audio Players & Recorders
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Top LeadSinger Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
