Question about Poulan Garden
How to replace coil
Need instruction on how to replace the coil
2004 Chrysler Pacifica coil pack replacement instructions
It says you need to remove the upper intake manifold to get to the coils,here's the link to it,then I will send the other link to removing the coils too. Repair Guides Engine Mechanical Components Intake Manifold AutoZone com Here's the second link on removing your coils. Repair Guides Distributorless Ignition System Ignition Coil AutoZone com
May 14, 2017 | Chrysler Cars & Trucks
There's 2 sets of numbers on the coil. The top i know is a part # but not sure about the bottom it's MA-15 1435 it's a Walbro coil
Rick, easiest just to order a coil by using make and model # of the chain saw.
MA 15 does show up a replacement Walbro coil.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Chainsaw Ignition Coil Test
Poulan Chainsaw Ignition Controls Parts
Poulan IGNITION COILS
Poulan
Apr 18, 2016 | Poulan Garden
How to replace coil
replacing them are simple. if you have a V6 you will have to take off the intake manifold to get to the inner set. pop them out and on.
Apr 20, 2014 | 2002 Lincoln LS
I changed the coil on a 2001 toyota corolla as instructed...unplug one wire and take out one bolt. car now missing worse than before.
Just need a repair shop to properly diagnose
a misfire issue
Different shop obviously
Codes do not tell you what is wrong or to
replace parts
Dec 18, 2012 | 2001 Toyota Corolla
A miss in my 1993 cougar
Please see my tip at http://www.fixya.com/cars/r6715318-causes_gasoline_engine_misfires . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with engine size info.
Jan 01, 2012 | 1993 Mercury Cougar
Where is ignition coil located on 1998 jeep cherokee and how to replace
It could be heating up but there are some tests you can do to rule this out. When the vehicle doesn't start, do you know if you are NOT getting spark to your spark plugs or are you NOT geting fuel. You need these 2 things to at least start the engine. If you do not it will not start. Basically you would be best to find out what is missing and then start diagnosing before you replace any parts. Feel free to email me at csautomotivecars@att.net with any questions or needing testing procedures. I went on below and gave you instructions as far as replacing the coil but I still stress the fact that you need to diagnose your problem first. Also this is for the 4.0 liter engine. Wasn't sure if you had the 4 cylinder engine so I went with the most common engine for your vehicle. I hope this helps.
Dec 18, 2011 | 1998 Jeep Cherokee
Dryer not heating. need instructions on pulling heating element out to replace.
Most dryers have a panel on the back where one can check the heater coils. Depending on the make, sometimes you have to remove the top and or the drum to access the coils. When you get to the coils you can replace or join(splice) them back together by forming a hook on each end and after hooking them back together twisting the free ends on themselves. This will work and you may not have to but a new coil. Kind of like a fishing knot without the knot.
Feb 23, 2010 | Dryers
I need to replace an ignition coil and plug on my 04 Ford Escape. Is this a difficult task? Can someone provide instructions?
If you have a V6 and it's like my 2002 V6, it will depend on with plug/coil you need to replace. The front 3 are very easy to replace. For the back 3, you'll need to remove the upper intake manifold (get a gasket set from the parts store).
Assuming it's a COP system (Coil Over Plug), each plug has it's own coil. Unplug the wires from the coil. Remove the one bolt with an 8mm? socket. Pull the coil off the plug. Using the correct socket, remove the plug.
If you have to remove the manifold for the back 3 plugs/coils, that will be more complicated. I would recomend going to:
http://escape-central.com
Add do a search for "intake manifold remove".
One of the first one's will have excellent instructions and photos.
Feb 08, 2010 | 2004 Ford Escape
Need to replace the spark plugs
The top of the engine has a cover remove to see ignition coils. Remove wires then coils, plugs are under coils. This is called coil on plug system. Make sure engine is over night cold before you do this, aluminum heads are easy to pull threads when they are hot. Always replace with OEM plug cheap plugs burn out coils !!!
Sep 27, 2009 | 2005 Toyota Corolla
Garden Logo
23 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
