Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
The monitor does not turn on.
It's plugged in. I tried on a different computer and power still does not come on.
    Champion:
  • 209 Answers
Are you using the correct cable from the PC to the monitor?
Posted on Sep 20, 2014
Power is on but monitor does not come on
check the cable, wiring harness, check the outlet for power, make sure you do not have it is a plug that may have switch some where where it turns or shut the power to that outlet.
or can it be video card issue, or plugs adapter is faulty, try a different outlet or different plug in your power strip. check the power strip if you have one, make sure the power strip is on, push the reset button on the power strip.
if you motherboard has internal vga adapter try setting resolution to the lowest setting plug you monitor into the motherboard to see if the issue is the video card or cards.
turn monitor off and on see if it getting warm.
the resolutions maybe to high try lower setting temp.
see if the monitor has manufactures restore or reset button on the monitor some where, it would be around all the connectors are located.
does the light comes on when you turn on in the front of monitor.
if all fails than it is time for a new one.
thank you rod
Apr 19, 2014 | BenQ G922HDAL 18.5 WIDE LED MONITOR
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
Unplugged my computer for 3 weeks. Plugged it back in, monitor powered up with the Xerox logo and nothing else. Now it won't power on after I tried turning if off and on...any suggestions?
First be sure that the problem is with your monitor and not with your computer, try plugging in a different monitor to the computer or a different computer to the monitor to isolate the problem. Often when leaving computers sitting for weeks at a time dust can build up in them that can cause fans to jam and computers to not operate correctly. Try dusting out your computer with some canned air dusters. If the problem is with the monitor it will likely need to be returned. Hope this helps!
Mar 16, 2011 | Xerox XG-91D 19" LCD Monitor
Monitor shuts off
Is the monitor light turning off, indicating the monitor is turning off? Or is the monitor/computer going to sleep?
How do you get the monitor to turn back on?
Verify the power cord is securely plugged into both the monitor and the outlet.
Try a different outlet.
Mar 12, 2011 | ViewSonic VX715 17" LCD Monitor
Monitor is black,power line flashing.
Flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the viewsonic logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Aug 15, 2010 | ViewSonic VX924 19" LCD Monitor
When i plug the monitor into my computer the flashes Benq only!
Try connecting the monitor to a different computer, e.g., a laptop.
The power-cord to the monitor seems to be OK.
Check the "data" cable between the monitor and the computer -- try a different cable.
With the monitor turned on, restart your computer, and watch the monitor. The computer should show some start-up messages (white text over black background), followed by the Windows "splash" screen. If it does, the monitor is working correctly.
Jul 03, 2010 | BenQ FP737S-D 17" LCD Monitor
The monitor will not come on when i turn it on
1. - Check for power at the socket. (plug in something else)
2. - Check for power at the power cable. (plug the cable into something else you know works)
3. - Plug into monitor, and see if ANYTHING lights up when the power switch is turned ON.
4. - If you get some indication of power, try a new cable to the PC, or plug into different PC. That will localize if it's the monitor, the cable, or the PC.
May 28, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
