Question about Kitchen Ranges
Kenmore gas ultra bake oven and broiler try to ignite but wont stay lit.
I own a gas Kenmore ultra bake self cleaning super capacity stove model#72022102 that is in my mountain cabin and was last used 4 months ago on our last vacation. It worked perfectly then. Now on our current vacation the gas stove top works perfect but BOTH the oven AND the broiler will not stay ignited. Both will make the normal clicking noise 3-4 times, ignite like normal but after 10-15 seconds they turn off and a few minutes later will repeat the process of igniting then shutting off. It does not display any codes, I have tried cleaning the little ignition prong for the broiler even though I am pretty sure that's not the problem since it's igniting just not staying on. The white wire that ignites the oven looks perfectly fine. Again, its happening to both the oven and the broiler. Any help is greatly appreciated as the man's favorite meal comes out of the oven. thanks.
  • 3 Answers
SOURCE: hotpoint 30" self cleaning gas range with sealed burners - no bake
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Posted on Nov 22, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: Kenmore 30
is the igniter electrical
it may beed clean as this is usually the problem
and sometimes age or klarge use does not help this electronical devises
Posted on Sep 27, 2009
  • 3640 Answers
SOURCE: Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Posted on Jan 31, 2010
Testimonial: "Thank you!! "
blueextc3221
  • 15935 Answers
SOURCE: kenmore oven model#362.7122891 gas oven and broiler wont work
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Element in oven gets red hot, burns food being baked, will not shut off unless I unplug oven. how to fix?
You need a new thermostat or oven sensor. These people are pretty good but I am have trouble find details on the model number you gave. This gives an idea.
http://www.appliancepartspros.com/kenmore-range-cooktop-oven-fuse-sensor.html
Another place here
http://www.partselect.ca/Model-Number-Locator+8+repair.htm
Nov 15, 2015 | Kenmore Kitchen Ranges
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
Jun 15, 2015 | Kenmore Ovens
Directions on how to use the self-cleaning feature of my Kenmore Ultra Bake Self Cleaning Super Capacity oven
First take out the racks (unless they are coated with the same porcelan coating as the oven interior). Press the Clean or Self-Clean button. Press up or down arrow key - 3:30 will show in display which represent time in hours and minutes. You can press the up arrow key for more time, or the down arrow key for less time, but usually the default time is good. Then just press Start. The door will lock and the oven will turn on. In 3 1/2 hours the oven will turn off, but the door won't unlock for another hour.
Sep 09, 2014 | Kenmore Kitchen Ranges
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Jul 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven keeps flashing E1-F3
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Feb 22, 2010 | KitchenAid KERC607 Electric Kitchen Range
I have a kenmore Ultra bake selfcleaning oven super capacity. after i set it for self cleaning the display started beeping and went completely blank. please help
It appears your ERC/CLOCK has failed in this instance.
Jan 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
Jul 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
