Question about Frigidaire GLEQ2152ES Electric Dryer
Error code rE5 what does it mean
When on switch is pushed it just hums. Does not start.
Error Code re5, dryer runs but no heat.
Good Afternoon Henry, thank you for your post!
I see that your Frigidaire dryer is displaying an error code of "re5" and will not heat. I have researched our available information for dryer and without having the model number the error code appears to be invalid. I would recommend performing a reset on your dryer and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment back with the model number? You can locate the serial tag (which lists your model number) on the door frame of your dryer. With that information I would be happy to assist you further. -Matt
Feb 22, 2016 | Frigidaire Dryers
Model # GLEQ2152ESO will not start just humming sound when you push start button. Error code rE5
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Apr 13, 2015 | Frigidaire Dryers
Spin dryer switch on but still hard to start otherwise if shafting is pushed clockwise it runs very slow.
Have try to turn the switch on top on the right and then hit start
Mar 10, 2015 | Dryers
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Updating RE5 and cannot sign to psnetwork
go to network settings and turn off the enternet then turn it back on
Mar 01, 2010 | Capcom Resident Evil 5 for PlayStation 3
Intel grafics card with wxp re5 game
think you need a new graphics card.
think shader 3 i think is the minimum to play re5
i could get the specs for the game if you like?
Sep 18, 2009 | Capcom Devil May Cry 4
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
