Magicjack error 3004 - Computers & Internet
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
Why magicjack shows error 20?
If your magicJack reads "Error 20", please follow the steps below.
If your magicJack reads "Error 20", please make sure that you have allowed exceptions on your Firewall/Antivirus for magicJack. The most common Firewall/Antivirus programs are listed
below. If your Firewall/Antivirus software is not listed, please refer to their web site or user manual.
You can download a document (pdf file) from MagicJack by going to What Is Voice Over IP Frequently Asked Questions magicJack
and putting error 20 in the search. This will then give you the 86kb long file with details on the most popular anti-virus software.
Nov 20, 2014 | magicjack.com Computers & Internet
Why does my MagicJack phone says error even after checing all my hook-ups?
On your softphone, please do the following:
  1. Click "Menu" on the top right-hand corner
  2. Click "Advanced Users"
  3. Click "Restart"
If your magicJack is plugged into your modem or router, unplug it from the power source, wait 30 seconds, and plug it back in.
Aug 31, 2014 | magicjack.com Computers & Internet
How can I fix my majicjack plus to work with anew service provider?
tab_l.gif Answer tab_r.gif If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
You need to check your new internet connection first.
Then sign into
You must check your new internet connection gets to magicjack.com
sign into VoIP Phone Service Internet Home Phone Service Providers magicJack
Jul 12, 2014 | magicjack.com
Magic jack error 4998
The is no such error message is listed.
Please contact customer service to resolve your error message.
International VoIP Phone Service Customer Care Support magicJack
May 31, 2014 | magicjack.com
Make a telephone-call to the "Customer Service" department at MagicJack, and say that you are getting "error 3004".
Mar 09, 2014 | Computers & Internet
Why won't magicjack download?magicjack problems
Dec 01, 2013 | Computers & Internet
Magicjack error 6
There is no listed error 6 in he FAQ.
Contact Customer Service International VoIP Phone Service Customer Care Support magicJack
Sep 26, 2012 | magicjack.com
Magicjack error 401 how do you fix
For error 4.
  3. Click "Restart"
If that does not work:
<Requires some technical understanding. Explanation below. >
  1. On your computer, go to Control Panel
  2. Go to Network Connections
  3. Right click on your active Internet connection
  4. Select Properties
  5. Scroll down to Internet Protocol (TCP/IP)
  6. Click on Properties.
  7. In there check the little circle that says "Use the following DNS Server address".
  8. In Preferred DNS Server type in: 67.90.152.122
  9. In Alternate DNS Server type in: 67.107.71.186
  10. Click OK and OK.
Now restart your magicJack, by following the steps above.
For error 1
To resolve this, make sure that one end of the ethernet cable is plugged into your modem/router/switch and the other end into your magicJack.
You also need to make sure that your modem/router/switch is powered on and that the port you have connected the magicJack to is functioning correctly.
Oct 21, 2011 | magicjack.com
Magicjack error 401
This error usually shows up when magicjack does an update. You will need double check if you can log into my.magicjack.com if you can then you will need to reinstall the magicjack software and try again. If you cannot log in then there is an update taking place and you will need to wait it out.
Hope this helps
Mar 08, 2011 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
