Question about Ignition System for Toyota RAV4
2014 rav4 ignition keyless won't start
All warning lights went on and ignition would not start
    Sergeant:
  • 462 Answers
Make sure you using ignition fob key
Posted on Sep 07, 2014
How to reset the change oil light on a 1997 rav4
rav4 reset maintenance light
pretty standard
hold trip A in with engine and key off while holding trip button in turn key and engine on.
keep holding trip button in until light stops flashing when it stops flashing then release the trip reset button this should clear the maintenance warning light. hope this helps
Dec 26, 2014 | 1997 Toyota RAV4
Car had been sputtering and stalling while stopped in "drive". Mechanic mentioned to change the thermostat so I did it myself. The problem still exists and now the blower for the heat and A/c doesn't
  • Doug Warne Your kia here is what i would do to help diagnosisMar 19, 2014
  • Doug Warne First of all i would do these steps"
    Mar 19, 2014
  • Doug Warne how does it run when cold how does it run when hot
    Mar 19, 2014
  • Doug Warne i would look for Vacuum Leaks
    Mar 19, 2014
  • Doug Warne i would remove the spark plugs check engine compression hope to see about 180 psi on each cylinder
    Mar 19, 2014
  • Doug Warne i would exam each spark plugs to see if fowled with Gasoline or carbon keep spark plug with each cylinder because low compression will cause this
    Mar 19, 2014
  • Doug Warne low compression i would exam cooling systemicon1.pngfor airbubles or coolant in engine oil
    Mar 19, 2014
  • Doug Warne if oil looks milky white in color its coolant do not operate vehicle
    Mar 19, 2014
  • Doug Warne change head gasket get head kit with valve cover and take head to machine shop to have shaved straight and checked for cracks Replace head with Remanufactured if warrpiage to great or stress cracks
    Mar 19, 2014
  • Doug Warne check air filter and breather to insure the intake is getting air before you do compression test
    Mar 19, 2014
  • Doug Warne if engine dies when hot lets look at the fuel pump pressure
    Mar 19, 2014
  • Doug Warne lets take and look at the fuel cap where you put your fuel in make sure the vent is open which allow outside air pressure becuase you can have a 100 billion gallon second pump but if there is no air coming into take the pump will pump 0
    Mar 19, 2014
  • Doug Warne Check your OBD 2 codes First this will give you ideas of what happening ie bad oxgen sensor telling me look for vacuum leak or poor spark ignition or poor engine compression, possible injector leaking
    Mar 19, 2014
  • Doug Warne poor compression tell me the engine maybe out of timing and or valves or worn or burnt exspecially when engine is hot and it dies
    Mar 19, 2014
  • Doug Warne a cylinder leak down test would be revealing for valves or piston rings
    Mar 19, 2014
  • Doug Warne if engine has good Intake of Air and gas mixture and then good compression of air and gas mixture and good spark from the Ignition and good flowing exhaust the engine will operated smoothly
    Mar 19, 2014
  • Doug Warne if engine looses power or stalls when hot take a look at the catyalitic converters to see if glowing red or hot one side and cooler on rear side also check the exahust pessure at tail pipe to see if cats are plugged if you have little exhaust pressure and no exhaust leaks
    Mar 19, 2014
  • Doug Warne i hope this helps and i always kiss the job.............
    Mar 19, 2014
  • Doug Warne Keep IT Simple Stupid
    Mar 19, 2014
    Mar 19, 2014
  • Doug Warne as far as the thermostat is the engine running hot..????
    Mar 19, 2014
  • Doug Warne CHECK FOR AIR BUBBLES IN COOLANT as piston compress air if it leaking pass the headgasket seal into the coolant jacket this will cause air bubbles and you may loose heat out of the heater core...i have seen this with cracked heads also so if this is the case have head checked at machine shop
    Mar 19, 2014
  • Doug Warne check the oil from the dip stick smell it see if you smell gasoline this is telling me thin oil, possible injector leaking gasoline
    Mar 19, 2014
  • Doug Warne Low engine Compression with satuerate oil the oil ring on the piston will have hard time to create seal to cylinder wall there fore low compression exspecially when engine is hot
    Mar 19, 2014
  • Doug Warne get a spray bottle fill with water and with engine runing spray water in coil packs and spark plugs wires to see if there cracked or frayed Electricty is lazy it will use the water as a ciricut and go to ground through the water this is telling me cracked coil pack or plug wires engine will began to miss and fumble while running
    Mar 19, 2014
  • Doug Warne these are some tricks i use to help diagnosis problems....hope this helps
    Mar 19, 2014
  • Doug Warne As far as the A/c Heater Blower i would first check the Fuse in the box with a test light, and i would check all the fuses remember you have a battery side and ignition side of the fuse box if the fuse is blow replace with manufacture Amp Fuse and if new fuse shorts then i would look at blower motor draw
    Mar 20, 2014
  • Doug Warne Check your battery Cold Crank Amps with a load test meter most parts store will do for free hoping you will buy a battery and if batter test not good if you choose to not to replace your alternator will be charging constentently and the trio diode board in your regulator located inside the alternator in most applications these days will short then this will cause a battery high amp draw so your battery wont start in the am when your late for work..
    Mar 20, 2014
  • Doug Warne If your battery is loosing charge overnight or anytime you can simply take your negaitive Cable from your batter and put a test light from the negiative cable then touch your neg. terminal and if test light illuminates you have a draw and bad draw so take amp meter and test to see the draw in amps if high amp draw i would first look at the regulator and remove the 12volt singe wire and see if draw disappear if draw is no longer then 99 percent your regulator has shorted
Mar 19, 2014 | 2001 Kia Sportage
"ps" warning light went on - says to see Toyota
On the battery on the positive section are fuseable link they are hard to see this protect the P/S it also turn on the alternator light and vice versa you need to check the fuse at the battery and also check the charging system
Aug 22, 2011 | 2006 Toyota RAV4
My vsc trac warning light and check engine light went on
Please, make your mechanic check the ABS computer. My RAV4 did the same thing, but the mechanical components were alright. After a while, I almost fell off a cliff because my brakes stopped responding properly. When further checked, my mechanic discovered that the ABS computer was damaged. The part alone costs a whooping $3 thousand bucks, not including labor. So, beware and take precautions. Your life may be endangered.
May 02, 2010 | 2004 Toyota RAV4
I just purchased a keyless 2006 RAV4. One of the
you dont need to worry,use the key as normal (put in lock to open door)it will still start the car,just split the remote with your hands and the battery is inside it,you can get one at the newsagent,or supermarket easy job
Oct 21, 2009 | 2006 Toyota RAV4
Rav 4 won.t start
I would look at the key. Is it the original. Didm you get an add on alrm system or remote start switch?
Jul 17, 2009 | 2008 Toyota RAV4
Keyless Remote 2008 RAV4
You can take it back to the dealer, and have them change the battery, or go to Autozone, buy the battery and do it yourself. They can show you how to do it. And which battery it takes. It's not hard to do. Good luck.
Jan 27, 2009 | 2008 Toyota RAV4
Ignition System for Toyota RAV4 Logo
59 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
