Question about Whirlpool GI5FVAXVL (249 cu ft) Bottom Freezer French Door Refrigerator
Control panel how do I remove
Maytag control panel
why do you want to remove the control panel?
much more info is needed...
you can gt to it by starting from the back and removing the screws from the top. push the top panel backwards and remove it from the cabinet. then you can access the front panel. it will have 2 screws holding it to the front. remove them and then lift the control panel up and off the front.
Nov 03, 2013 | Maytag Washing Machines
3G Mitsubishi Eclipse Climate Control Light Bulb Replacement
The control panel for the heater and A/C must be removed. Suggest you get Chilton's manual from the library. It will take you through step by step with pictures. To summarize: 1) Remove trim panel covering radio and heater controls. 2) Remove radio. 3) Disconnect the two heater control cables from the control panel. The trick to removing the cables is to compress the "claw" spring holding the cable by pressing a screwdriver from the underside of the control panel to release each cable.4) Remove control panel. Take to a workbench. From the backside of the control panel at the top, notice two large holes through which you can access the V2 Toshiba bulb holders. Turn them a quarter turn to remove them and the bulbs. The bulb is a common #74 bulb.
Apr 22, 2012 | 2001 Mitsubishi Eclipse
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
Oct 04, 2011 | Panasonic Microwave Ovens
What step are taken to remove a dash from a 1996 lincon towncarto access the a/c heater blend door actuator
what is the issue? May not be the blend door motor. Big job.
The climate control assembly has three control knobs (18519):
  • The airflow control or function selector knob controls vacuum and electrical applications.
  • The temperature control knob, attached to the potentiometer, controls the position of the A/C electronic door actuator motor (19E616) mounted on heater air plenum chamber (18471).
  • The blower motor control knob, attached to the heater blower motor switch (18578), provides four speeds of blower motor operation.
A/C Electronic Door Actuator Motor Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove instrument panel (04320). Refer to Section 01-12 .
Instrument Panel Removal
  1. Position wheels straight ahead.
  2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  3. Raise vehicle on hoist. Refer to Section 00-02 .
  4. Remove RF wheel and tire assembly. Refer to Section 04-04 .
  5. Remove retaining nut in radiator coolant recovery reservoir area.
  6. Remove bolt retaining front fender apron (16054) to front fender (16005).
  7. Position front fender splash shield out of the way.
  8. Lower vehicle.
  9. Tag and remove wiring connectors.
  10. Remove retaining screw in parking brake control (2780). Remove parking brake control.
  11. Remove screw retaining instrument panel steering column opening cover reinforcement (04502).
  12. Remove steering column assembly. Refer to Section 11-04 .
  13. Remove from the LH and RH cowl side trim panels (02345).
  14. Remove lower cowl side trim panels.
  15. Tag and disconnect wiring connectors in LH and RH cowls.
  16. Remove ground wire assembly.
  17. Remove retaining rivet in the passenger side of the instrument panel (04320).
  18. Unsnap the instrument panel finish panel (04338), center and RH.
  19. Unsnap the instrument panel finish panel, (LH).
  20. Remove and disconnect the radio chassis (18806).
  21. Remove retaining screw in the instrument panel finish panel.
  22. Position the instrument panel finish panel out of the way.
  23. Tag and disconnect the wiring connectors.
  24. Remove retaining screw in the passenger side air bag module (044A74).
  25. Disconnect the electrical connector to the passenger side air bag module.
  26. Remove and disconnect the instrument panel upper finish panel (044A90).
  27. Remove instrument panel to cowl brace retaining screw.
  28. On Crown Victoria, Grand Marquis, remove screws retaining instrument panel finish panel (044D70) and remove instrument panel finish panel.
  29. Remove retaining nut on the instrument LH and RH lower finish panel.
  30. Remove instrument panel cowl brace (045D56).
  31. Disconnect vacuum hose on the harness assembly.
  32. Remove upper and lower screws retaining instrument panel finish panel to dash panel (01610).
  1. Disconnect the A/C electronic door actuator motor electrical connector.
  2. Remove four A/C electronic door actuator motor retaining screws.
  3. Remove A/C electronic door actuator motor (19E616).
Jun 14, 2011 | Lincoln Town Car Cars & Trucks
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
Where is the windshield washer motor located? Is it near the heater motor? I had mine fixed and now the heat comes out of the dash for the defroster
Windshield Washer Pump Removal & Installation To Remove:
  1. Remove the air cleaner assembly.
  3. Position the pump and reservoir aside.
  4. Disconnect the electrical connectors.
  5. Disconnect the washer hose.
  6. Remove the pump and reservoir.
  7. Remove the washer pump.
WARNING
Windshield washer solution contains methanol which is poisonous. Observe all cautions and warnings indicated on label of washer solution container.
NOTE: Windshield washer fluid should be collected in a container after the windshield washer hose is disconnected.
To Install:
WARNING
  1. Install washer pump in reservoir.
  2. Install washer pump reservoir assembly.
  3. Connect washer hose.
  4. Connect washer electrical connector.
  5. Install air cleaner assembly.
The windshield wiper fluid pump is located in the tank which is not in the heater motor or defroster area in the dash.
The defroster/heat control door is located in the dash board area:
Air Door Actuators, Cables or Motors Removal & Installation Air Inlet Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel lower insulator cover.
  2. Disconnect the vacuum connector.
  3. Remove the control arm clip and the spring.
  4. Remove the nuts and the air inlet door vacuum control motor.
To Install:
  1. Install the vacuum motor on the mounting bracket.
  2. Connect the control arm and spring.
  3. Connect the vacuum hose to the vacuum motor.
  4. Install the lower instrument panel lower cover.
Floor Defrost Door Vacuum Control Motor To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the left lower dash insulator panel and disconnect the lamp.
  3. Remove the two pin-type retainers and remove the fill panel.
  4. Remove the DLC mounting screws.
  5. Detach the vacuum line.
  6. Remove the lighting module.
  7. Remove the screws and the bracket.
  8. Remove the floor/defrost door vacuum control motor.
Floor/Defrost vacuum motor mounting screws for-10-00-246.gif
To Install:
  1. Connect the vacuum lines and install the floor/defrost vacuum motor.
  2. Install the bracket and lighting control module.
  3. Install the DLC bracket and mounting screws.
  4. Install the fill panel.
  5. Install the left lower dash insulator panel.
  6. Connect the negative battery cable.
Panel Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel.
  2. Reach through the door opening and remove the pin.
  3. Disconnect the panel door vacuum control motor vacuum line.
  4. Remove the screws and remove the panel door vacuum control motor.
To Install:
  1. Install the panel door vacuum motor.
  2. Connect the vacuum line to the panel door motor.
  3. Reach through the opening and install the pin to the linkage.
  4. Install the instrument panel.
Jan 19, 2011 | 2003 Mercury Grand Marquis
97 nissan maxima switch doesnt work on 1,2,3 but work on number 4 only. what is wrong and how can i fix the problem. how can i r&r the climate control panel. thank your
problem is usually the resistor, but switch may be going bad too. The resistor is next to the blower motor, above the passenger's feet. You may have to take the glove box out to get to it. See picture below. Also, please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow for additional diagnostic info. Please get back to me if you have any questions.
                        REMOVAL & INSTALLATION, Climate Control Panel
                        1. Remove the center console trim fascia.
                        2. Remove the radio to allow access to reach behind the control panel.
                        3. Remove the control panel attaching screws.
                        4. Remove the center console bracket, if necessary, to allow for easier removal.
                        5. Separate the control panel from the trim panel.
                        6. Unplug the harness connectors and vacuum lines from the control panel.
                        To install:
                        1. Plug in the harness connectors and vacuum lines from the control panel.
                        2. Install the control panel into the trim panel.
                        3. Install the center console bracket, if removed.
                        4. Install the control panel attaching screws. Do not overtighten them, as they are screwed into plastic.
                        5. Install the radio.
                        6. Install the center console trim fascia.
                        7. Operate the climate controls and check for proper operation.
                      Dec 13, 2010 | 1997 Nissan Maxima
                      Only cold air is available, what can I do to fix the blend door temporarily
                      I would repair the problem if I have to disassemble the varioius parts to get at the air doors --- In-Vehicle Temperature Sensor Removal & Installation To Remove:
                      1. Remove the climate control head.
                      2. While pressing the retaining tabs inward, remove the in-car temperature sensor.
                      To Install:
                      1. While pressing the retaining tabs inward, install the in-car temperature sensor.
                      2. Install the climate control head.
                      Air Door Actuators/Motors Removal & Installation Air Inlet Door (Recirculation) Vacuum Motor To Remove:
                      2. Remove the air inlet door motor mounting screws. CAUTION
                        Do not attempt to bend any part of the air inlet duct door lever.
                      3. Rotate and remove the air inlet door vacuum control motor.
                      To Install:
                      1. Rotate and install the air inlet door vacuum control motor.
                      2. Install and tighten the mounting screws.
                      3. Install the instrument panel.
                      Defroster Door Vacuum Motor To Remove:
                      1. Remove the passenger air bag module from the instrument panel.
                      2. Disconnect the vacuum line and remove the mounting screws. CAUTION
                        Do not attempt to bend any part of the defroster airflow mode door lever.
                      3. Rotate and remove the vacuum control motor from the defrost door lever.
                      To Install:
                      1. Rotate and install the vacuum control motor on the defrost door lever.
                      3. Connect the vacuum line to the vacuum control motor.
                      4. Install the passenger's air bag module.
                      Floor Console Register Duct Vacuum Motor To Remove:
                      1. Remove the floor console.
                      2. Remove the right-side instrument panel insulator.
                      3. Working from the passenger's footwell, disconnect the vacuum hose.
                      4. Remove the screws and the floor console register duct vacuum control motor. CAUTION
                        Do not attempt to bend any part of the floor console register duct door lever.
                      5. Rotate and remove the vacuum control motor from the floor console register duct door.
                      To Install:
                      1. Rotate and install the vacuum control motor onto the floor console register duct door.
                      3. Connect the vacuum hose to the floor console register duct vacuum control motor.
                      4. Install the insulator under the dash.
                      5. Install the floor console.
                      Panel/Floor (Heater Air Damper) Door Vacuum Motor To Remove:
                      Panel/floor door vacuum control motor shield ford-10-00-403.gif
                      1. Working through the driver footwell, remove the two screws and the shield. CAUTION
                        Do not attempt to bend any part of the airflow mode door lever.
                      2. Label and disconnect the two vacuum hoses.
                      3. Remove the vacuum control motor mounting screws.
                      4. Lift, rotate and remove the panel/floor (heater air damper) door vacuum control motor from the door lever.
                      To Install:
                      1. Install the panel/floor (heater air damper) door vacuum control motor on the door lever.
                      3. Connect the vacuum hoses in their original positions.
                      4. Install the shield on the vacuum motor.
                      Temperature Blend Door Actuator To Remove:
                      1. Remove the integrated control panel.
                      2. Remove the right-side lower instrument panel insulator.
                      3. Lower the glove compartment.
                      4. If equipped with Electronic Automatic Temperature Control (EATC), remove the 2 remote climate control module screws and position the module aside.
                      5. Remove the temperature blend door linkage shield.
                      6. Disconnect the temperature blend door electrical connector.
                      7. Remove the temperature blend door actuator mounting screws.
                      8. Remove the temperature blend door actuator.
                      To Install:
                      1. Position the temperature blend door actuator on the plenum.
                      2. Install the temperature blend door actuator mounting screws.
                      3. Connect the temperature blend door electrical connector.
                      4. Install the temperature blend door linkage shield.
                      5. If equipped with Electronic Automatic Temperature Control (EATC), reposition the remote climate control module and install the 2 mounting screws.
                      6. Raise the glove compartment.
                      7. Install the right-side lower instrument panel insulator.
                      8. Install the integrated control panel.
                      Nov 05, 2010 | 2000 Ford Taurus
                      Jenn-Air JDS9860AAP Control Panel Problem
                      Control Panel
                      1. Remove power from unit.
                      2. Remove burner switch control knobs.
                      3. Open oven door and remove screws securing control
                      panel.
                      4. Remove screws located on the right and left sides of
                      the control panel.
                      5. Grasp control panel on the far left and right sides and
                      gently pull the control panel out and down.
                      NOTE: Gently pull control panel out and down.
                      6. Remove infinite switch control knobs, infinite
                      switches, indicator lights, rocker switches, and
                      electronic control/clock (as necessary) and transfer to
                      7. Reverse procedure to reinstall control panel.
                      Electronic Control
                      1. Remove control panel, see “Control Panel”
                      procedure, steps 1 through 5.
                      2. Remove screws securing electronic control bracket to
                      control panel.
                      3. Label and disconnect terminal wiring from electronic
                      control.
                      4. Reverse procedure to reinstall electronic control.try that
                      Jan 16, 2008 | Ovens
                      Belling DB3 Control Panel
                      Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
                      Replacement is reversal of above.
                      Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
                      Whirlpool GI5FVAXVL (249 cu ft) Bottom Freezer French Door Refrigerator Logo
                      24 people viewed this question
                      Top Whirlpool Refrigerators Experts
                      John Tripp
                      John Tripp
                      Charles T Nevin
                      Charles T Nevin
                      Dan Webster
                      Dan Webster
                      Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
