Question about Nortel 2002 IP Phone
I have a Nortel 350 and the screen has become mostly unreadable but the information is still there. Is it possible to find a replacement for the slide-out screen or will I have to replace the phone?
I have the same problem. But instead of waiting around for solutions, I went inside the module and took a look. It looked interesting, lets just say that. When I gave up and but the circuit board back, RIPPPPPPP!! The little ribbon cable for the screen ripped off the circuit board. I am now devastated for now there is nothing on the screen. You can opt to buy a new module from here http://toonieshop.com/index.php?main_page=product_info&cPath=2_6&products_id=30
Posted on Jan 12, 2012
My pixels on the display are getting lines through them. Impossible to read. Can this be fixed? This is a Nortel 350 USWEST phone.
Find a local TV repair shop. Most can change the screen if a replacement is available. They will advise you best.
May 02, 2018 | The Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Samsung n 210 screen becomes unreadable
These screens have a fluorescent light behind them. If that light is flaky, the screen will go dark. I'd suggest checking that. They usually can be replaced--but carefully.
Feb 21, 2012 | Samsung N210JA02 Netbook
Can anyone explain why my pc screen will suddenly become jagged and unreadable? I can sometimes get it to clear up by refreshing or restarting, but what a pain! My computer is only 3 months old.
Here is a list of things to check.
Cable to monitor.
Machine is full of dust and is over heating.
(open it up and use a vacume to get all dust.)
Video card or power suppy is defective replace or if applicable return pc for warranty.
IT is also possible that if this is a custome machine that the power supply is too small and is being overloded.
May 17, 2011 | Compaq Computers & Internet
Why wont red Message light on my Nortel Phone
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s that left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Jan 13, 2010 | Nortel T7316E 2-Line Corded Phone
M2616 display problem dark screen not showing
If it is caused by an incorrect contrast adjustment YES you can fix it.
Press "Program", then "0", then "2", then slowly repeat the "Left Arrow Key" and the display should lighten and become visible again, once satisfied with the contrast setting, press "Program". If you lighten it to far, press the "Right Arrow Key" to darken it again. If this does not work, it is a hardware fault and not repairable by a user.
Mar 22, 2009 | NorStar Nortel M2616D Hands Free Phone...
Nortel 3120 Secure Router
NetFlow is a network protocol developed by nortel Systems to run on router IOS-enabled equipment for collecting IP traffic information
Jan 30, 2009 | Nortel 3120 Router (SR2102002E5)
Nortel 2002 IP Phone Logo
976 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
