Question about OKI Office Equipment & Supplies
Drive full error press online - OKI Office Equipment & Supplies
Kenmore HE2 Plus fronload washer is showing F- as an error code. there are no numbers in the error code. just "F-" i cannot figure out what that means
press and hold the power button until the machine resets,then if machine resets, ok. but if machine shows a fault it should give a full fault code.adrian,,,,,,,
Jan 24, 2015 | Kenmore HE2 Plus Front Load Washer
Keep getting error message space running low how do i clean
Most computer are shipped with the hard drive split into two sections. One is intended to be used, the other is typically a recovery partition which allows you to reset the PC back to factory settings. If ANY files are saved to this partition, you will receive drive full messages. Removing files and uninstalling programs will not help. Look for a drive D: E: or F:. Check these drives for any files you may have not knowingly saved there. Removing these should resolve your issue. Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Jan 04, 2015 | Tablets & eReaders
Toshiba satellite pxe-m0f
I would check the hdd is OK and not full of errors. When you press F8 just before boot can you select restore? If you can the restore partition is OK and it will restore itself to factory condition. If you can't, re run your restore discs or use an OS disc and install drivers when you get online.
Mar 19, 2014 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
I changed my ink cartridges and now I have an SC542 Error Code, Can I override it?
In order to clear error SC542, you can perform the following:
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arrow to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
Please let us know if this works for you.
Also, check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made. read this TSB on updating the thermistors: TSB_106 SC555_SC545_SC542 Occurs.pdf (need to register to views).
Hope helps.
Apr 04, 2011 | Office Equipment & Supplies
How do I reset a Lanier 226CN Printer with an error code: SC542
Press Enter
Press Enter
Press Enter
Power off and on.
Hope helps.
Apr 04, 2011 | Lanier LP231CN Laser Printer
Absorber tank is full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 01, 2009 | Canon Office Equipment & Supplies
THE WORK ORDER MACHINE IS GIVING ME A CA DRIVE ERROR IT IS A LEXMARK 4227 MACHINE.
Error: "637 Machine Check CA Drive Error"
Tear off any paper at the top of the printer.
Press the Load/Unload key.
Turn the printer off.
Press and hold the FormFeed button and turn the printer back on as you do so. Note: Hold the FormFeed button down for a full three seconds after turning the printer on before releasing it.
Press the Micro Up or Micro Down to change the value of the position "Pos = XXX".
Press the Tear Off/Store button to save the setting.
If needed, repeat steps 1-6.
Oct 06, 2009 | Lexmark 4227 Matrix Printer
I have a d 80 nikon and encounter following problem. when i press the shutter-release button i am getting following message error 07. I then pressed again the shutter release button. The same error...
I dont think this is actually an error but,
the "07 is just telling you that the camera is in Raw shooting mode and in that mode you can shoot 7 shots one after the other (with continuous shooting mode on) before the buffer gets full.
See page 140 of the manual and also read about RAW mode settings on your camera.
Cheange the setting from RAW and try taking a pic to see that your "error" goes away.
Please rate our help to keep us online
Aug 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
66 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
