Question about Body Sculpture Br2700 Foldable Fan Rower
Tension low on body sculpture br 2700
How can i increase the tension on this machine
How do I reset stitching I can only sew 11 stitches at a time I have to release Foot pedal each time
if turning the machine off/on again doesn't clear the machine then it needs to be checked
Jan 24, 2016 | Sewing Machines
The bottom thread is real loopy. I have adjusted the top tension and it helps a bit but still to loose
Remove all the thread from your machine. Install a brand new needle. Raise the presser foot and re-thread the upper thread, making sure you are following the correct threading sequence. Confirm that the bobbin thread is threaded through the bobbincase properly. Now, perform another test stitch. Is the bobbin thread still looping?
If you have already tightened the upper thread tension and the bobbin tension is still too loose, then you may need to tighten the bobbin tension. First, mark with a permanent marker where the slash of the screw head meets the bobbin case. This will mark where the screw was originally set before you begin making adjustments and allows you to return the screw to that position should you need to.
Set the upper tension to the halfway point between the high & low number. This is what would normally be the standard.
Then gently turn the bobbin tension screw to the right 1/8th of a turn at a time. Then test. Keep adjusting until the bobbin thread tension is correct. The tensions are correct when the upper thread and the bobbin thread meet in the middle of the fabric.
Nov 15, 2015 | Sewing Machines
Why is top thread tension too tight?
rethread top thread on the machine with a heavy weight thread or string, not threading the needle. Pull it out backwards and it will clean out the tension disks. You probably have threads and lint jammed in it.
Aug 03, 2015 | Sewing Machines
I need new bearings for seat of body sculpture rowing machine br 3050
Remove the bearings and take them to your local Industrial Supply retailer, they should be able to cross reference and get you the ones you need.
Feb 24, 2015 | Exercise & Fitness
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Help! Tension Problems
Looping on the top means there is no tension on bottom. The bobbin thread generally rotates counter clockwise. The thread must get under the tension spring. The spring must be adjusted equal to the top tension. This you will have to play with to tighten or loosen as needed. When you sew in a zigzag you might want to loosen the top tension slightly. On a regular basis remove the bobbin case and clean with a qtip. On the race put one drop of sewing machine oil. Clean the bobbin case and replace.
Mar 25, 2017 | Singer 57815 Mechanical Sewing Machine
Body Sculpture Br2700 Foldable Fan Rower Logo
53 people viewed this question
Top Body Sculpture Exercise & Fitness Experts
Electro Med Services...
John
ray gallant
Are you a Body Sculpture Exercise and Fitnes Expert? Answer questions, earn points and help others
