Question about Thermador Ovens
Will not heat
Will not turn on
    Champion:
  • Thermador Expert
  • 323 Answers
Need a model number
Posted on Feb 03, 2015
Hi I have an old 1970's St.george imperial wall oven and I can't turn the roast light off which makes the oven heat up to under half the heat it normally does. How do I turn the roast light off?
since I have no model or serial, I assume this is an electric oven based on the description provided. this is usually an indication that the heating element has gone bad. possibly having a short to ground which completes a partial circuit in turn giving you heat and a light. I would look in this direction first.
Jan 04, 2018 | Imperial Ovens
Main oven keeps going off
If you mean the heat keeps turning off??? The heat will turn off when the thermostat detects the desired heat level has been met, after that, when the level of heat goes below the selected level then the oven will heat up again granted if the thermostat is functioning correctly. This is the best answer I can provide for vagueness of the question.
Nov 03, 2013 | Baumatic Ovens
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
Oven turns on but won't heat up
the oven almost certainly needs a replacement element which should be the responcibility of your landlord.
Nov 23, 2009 | Ovens
Top oven will not turn on elements, bottom oven turns on elements
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
Oven won't heat up
Ok, this is a definite element malfunction. you can confirm this by using a multimeter and connecting the meter to the terminal points on the element. once connected, turn on the heating cycle and if you can register a reading and the element dosen't light or produce any heat, this will confirm element failure and you will need to replace it.
Please rate and god bless:)
Apr 20, 2009 | Ovens
OVEN TURNS ON BUT WONT HEAT UP.
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
