Question about 2002 Nissan Altima - Fits Models with a 2.5L 4 Cylinder Fuel Injection Engine - Premium Wrench-Off Oil Filters
Replaced The ECU Computer and now the car will not start
Replaced the ECU computer and now the car will not run
    Master:
  • 710 Answers
Make sure you used the correct computer. Also the ecu may need to be reflashed at the dealer.
Posted on Sep 01, 2014
Can a vehicle run with a non functioning ECM?
if the check engine lite doesn't work it most likely needs cluster removed and bulb replaced its blown. if the computer is bad it wont run. I wanna say that ecu fuse will clear code from computer but its not main power to it. I would start with the bulb that way you can get code.
Feb 18, 2015 | 1994 Toyota 4Runner
Battery cables switched
Make sure an OBD reader is used to make a connection to the car's ECU/ECM. If no connection can be made, then you can remove the ECU and test it for current and resistance. If either of those tests fail, your car needs a new computer.
Feb 10, 2014 | 1993 Lexus Es 300
94 ranger cranks but will not start
have you linked the ecu to the immobiliser as you said that you have changed the ecu (computer) with out it linc the imobiliser will be on and no fuel or power will go to the engine.
Sep 25, 2013 | Ford Ranger Cars & Trucks
How much to fix the ECU computer on 1995 Jeep Wrangler?
No software upgrade will fix that bad ecu. There are electronic components inside the ecu that need to be replaced. Services for repair or replacement of your ecu are available on ebay.
Jul 31, 2012 | 1995 Jeep Wrangler
Replaced the ecm computer on 2001 dodge durango then start it up and it runs and then cuts itself off after 15 seconds
The ECU would have to be programmed from the dealer. It normally costs somewhere around $100 to have it reprogrammed. The reason it needs reprogrammed is because the factory theft module in your car is different than the theft module in the car that the "new" ECU came from. I had this problem with my 1997 Cadillac Deville.
All you would have to do is get it to a Dodge dealership and have them reprogram the ECU. Make sure you explain that you just replaced the ECU, and you need it reprogrammed to match your SUV.
Please vote on my solution whether good or bad. Thanks! :D
Oct 25, 2009 | 1999 Dodge Durango
Problem with my 2007 suzuki XL-7 Computer
if you replace the ecu (computer) it will work fine.
it will have to adjust to new engine sensor settings,but it does that by itself.
most ecu are damaged by jump starting
Apr 26, 2009 | 2007 Suzuki XL-7
Engine Control Unit(ECU)
The ECU is a Direct Link to the Onboard Computer. You may need to get the Computer Replaced or at Least have a Mechanic run a Diagnostics Check on it. The reason it is acting this way is Because you are just Clearing the Trouble Codes by removing the ECU for a while. It is still sending a Fatal Error after Driven for a While.
Jan 21, 2009 | 1997 Volkswagen Golf
Wont start
DME relay is faulty, its seperate from the ecu and was most likely fried when the ecu went........did anyone try to run an on board diagnostic code pull?
Jan 11, 2009 | 2001 BMW Z3
2002 Nissan Altima - Fits Models with a 2.5L 4 Cylinder Fuel Injection Engine - Premium Wrench-Off Oil Filters Logo
50 people viewed this question
Top K&N Products Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K&N Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
