Question about Premier Pro P36S 36" Commercial Style Gas Range with 3.9 cu. ft. Manual Clean Oven, 6 Sealed Burners, Electronic Ignition, Broiler Drawer, Storage Compartment and Griddle Included
On our Premier Pro Series 36 inch 6 burner gas range - when we turn the oven on and set it to correct temp. the electronic ignite clicks and lights properly, but when it reaches the desired temp, the
We aren't sure if there is a problem with the ignite for the oven, the knob, or maybe a thermostat issue. Please give us suggestions for fixing it ourselves before we spend $$$$. Thank you
    Top Expert:
  • Premier Master
  • 44,268 Answers
How can we tell when you seem to have forgotten the most important part of the question .
Posted on Apr 16, 2015
3 Suggested Answers
meztang
  • 112 Answers
SOURCE: Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Posted on Jul 16, 2010
heatman101
  • 43501 Answers
SOURCE: Premier 20" range with electronic ignition - the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 08, 2010
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
Premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Oct 28, 2008 | Premier P36S318BP Gas Kitchen Range
Sep 17, 2007 | Premiere Ranges P36S328BP Stainless Steel...
Premier Pro P36S 36" Commercial Style Gas Range with 3.9 cu. ft. Manual Clean Oven, 6 Sealed Burners, Electronic Ignition, Broiler Drawer, Storage Compartment and Griddle Included Logo
192 people viewed this question
Top Premier Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
