Question about PLANMECA PM 2002 EC Dental X-Ray
Vertical lines on digital panoramic x-ray
Vertical lines show after developing in scanX
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
Fault finding
Bad connection on the cmos chip, send it in.
Dec 02, 2013 | Panasonic Cameras
VERTICAL LINES ON SCREEN
So it's no longer under warranty.... right? The problem you describe is control by a 'digital' driver IC (integrated circuit chip) which has apparently developed temperature problems.
Jun 30, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Two vertical lines one at 1/3 screen the other at 2/3's of screen
I have not fixed it yet. But I have identified the chip that is causing the problem. If you have a service manual scan it and post it please, so I can show you the chip.
Aug 04, 2007 | Toshiba 57H81 57" Rear Projection...
Red lines
It seems that you have been selecting Panoram view to shoot photos. Go to menu and change the image options and select SHQ or whatever and not panorama. This should solve the problem. Panorama view shows the grid lines all over the screen and it is meant for taking 360 degree panoramic views.
Jun 13, 2007 | Olympus FE-230 Digital Camera
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
PLANMECA PM 2002 EC Dental X-Ray Logo
100 people viewed this question
Top PLANMECA Medical Experts
Electro Med Services...
Are you a PLANMECA Medical Expert? Answer questions, earn points and help others
