Question about SNK Magnavox 32MF338B27 32 in. LCD TV
Magnavox 32MD357BLCD TV and DVD player
I need a power switch capasitor
Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Feb 02, 2012 | Magnavox Televison & Video
Hooking a magnavox vcr dvd player to a tv
You need what they call an "RF Modulator". They are about 25$. Here is a link to one...
http://www.radioshack.com/product/index.jsp?productId=2103095
Jul 08, 2010 | Philips Magnavox DVD/VCR Dual Player
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox mrv640-accidentally turned on progressive scan
Had exactly the same problem. You need to reset the DVD recorder to it's default setting. The default is "interlaced".
From the users manual.........
Switching the DVD Recorder
Disconnect the recorder's power cord.
2 Hold down the FF button (arrow pointing left) the front of the DVD Recorder while
reconnecting the power cord. 'PRO' (progressive scan) will appear
on the display.
3 If you want to switch back, repeat steps 1 and 2 . 'PRO'
(progressive scan) will disappear from the display. The DVD
Recorder is switched to 'Interlaced.'
The manual is at:
http://www.m4c.magnavox.com/files/m/mrv640_17/mrv640_17_dfu_aen.pdf
See page 12
It worked for me.
Mike
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
SNK Magnavox 32MF338B27 32 in. LCD TV Logo
12 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
