Question about J River CDL Commercial Driver's License Manual by AplusB for PC
Weight of 30ftWINNEBAGO CHIEFTAIN
IS THAT REQUIRED TO DRIVE THE MOTORHOME?
Curb weight 1986 29 foot southwind motorhome
The weight is about 17000 lbs.
The weight is posted somewhere in the RV. Could be on a visor, inside a closet or cabinet door, or on a door panel.
Oct 09, 2016 | RVs
Dash a/c wiring diagram for 1998 Winnebago chieftain
Billy, 1998 Winnebago chieftain a/c wiring diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring Diagrams
http://www.winnebagoind.com/diagram/Wiring.htm
http://www.rialtainfo.com/winnebago/winnebago_images/service_bulletins_2002-02_7sb003-02-02a.pdf
1998 Winnebago chieftain wiring diagram Google Search
Aug 20, 2016 | Cars & Trucks
Honestly, I need to know the approximate weight of a 1990 Ford Mallard Motorhome and cannot find that information anywhere online.
Hi Jenn:
You could get the exact weight without too much trouble.
If there is a gravel pit nearby (or a highways weigh scale) all you need to do is ask and they will let you drive over their scales.
Ta Da!!!! The exact weight.
If you look at your registration there should be a place where the GVW is recorded.
Aug 29, 2015 | Cars & Trucks
We have a motor home we want to tow our 2008 Rouge Nissan AWD is it safe or what has to be done to it to avoid problems. We want to tow on all 4 wheels.
first thing is you have to know the weight of the motorhome..and you must know the towing capacity of the nissan..
but if and when you decide to tow the motor home always keep in mind .especilly if you have never towed anything like that before.That when big trucks pass you the trailer will want to sway back and forth.so always keep that in mind.....and safe driving....
Oct 20, 2010 | 2008 Nissan Rogue
I have a 1999 Bounder 34J motorhome on a Ford V10 chassis. I would like to carry a 400 lb motorcycle and carrier on the class III hitch on the back of the motorhome. Total weight will be under the 600 lb...
the only way you will know for sure is to try it. chances are it should be ok. depending on how far you plan to travel, you may want to have a front wheel alignment performed WITH the bike on the back, because if the front end moves up slightly it may change your camber / toe, adversely affecting handling and tire wear.
Mar 06, 2010 | 1999 Ford Super Duty F 450
Can this car be flat towed behind a motorhome?
AS LONG AS THE DRIVE SHAFT IS REMOVED.
Sep 03, 2009 | 2002 Honda Passport
I have a sundance motorhome and have bought an a frame want to tow a kia rio 1.5 diesal is it in the weights the motorhome can tow a combined weight of 5400 kgs including the towing unit and car
Unless your Rio is extremely overweight......
5400kgs is nearly 12,000 lbs, your Rio's curb weight is 2365lbs and the frame can't possibly weigh more than a few hundred, unless what you are calling a "frame" is actually a car trailer..... (even then it won't be more than your Sundance can tow).
The internet is very good for doing simple searches.
Sep 03, 2009 | 2007 Kia Rio 5 Sx M/T Hatchback
Oil weight
What it says on cap.
Jun 13, 2009 | 1986 Toyota Xtracab
J River CDL Commercial Driver's License Manual  by AplusB for PC Logo
16 people viewed this question
Top J River Computers & Internet Experts
David Payne
David Payne
Are you a J River Computer and Internet Expert? Answer questions, earn points and help others
