Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberline 1/2 hp belt drive opener that stops opening
Opens up to 1 ft and closes fine. Will run when not connected to door. Door will open fine manually. Springs are not broke and were replaced about 2 years ago.
  • fosfam Jun 16, 2009
    Not very heavy.Twice today it actually worked.Each time after it had been setting quite a while. I did check the springs out pretty well and could not see any breaks, the springs are only about 2 years old.I'm thinking maybe spring adjustment, bad belt,up pressure too low?
    President:
  • 3,197 Answers
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Posted on Jun 15, 2009
My new installed garage door opener closes and opens right away
You have to adjust the safety pressure sensor. It is set to too light a pressure. Check your manual for the adjustment.
Mar 10, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
Nov 05, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door only opens partially and then stops
IF THE DOOR WORKS WELL MANUALLY.
ADJUST THE UP SENSITIVITY ABOUT 1/8 TURN AND TRY AGAIN.
HOPE THIS HELPS
Jun 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens about 18" and stops
Check the drive belt for tightness. Check for a bent or obstructed track. Overhead door openers have a safety clutch built in in case something or someone gets into the path.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garrage door opener won't open all the way and sometimes it won't close also
If the door runs fine then check the up force and down force on your operator (the box that hangs from the ceiling). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up/down arrow to a higher number.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
149 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
