Question about Toshiba DVD/Video Cassette Recorder DKVR60KU
Toshiba DVR670KU Front Panel Display blinking on and off
During recording on DVD front panel display began blinking on and off.
cammykins
  • 149 Answers
SOURCE: Toshiba 62HM14
Here is some useful information off of the manufacturer's product information PDF regarding the lamp problems/issues: LED indications: The green and red LED lights on the TV control touchpad (on the lower right corner of the TV screen)indicate the TV?s current status, as follows: ? Green ON = Control touchpad being pressed. ? Red ON = Power ON. ? Green and/or Red blinking 35) Special care for D LPTM (digital light processing) units: ? Lamp?The lamp in this product has a limited service life. The length of service life varies depending on product use or user settings. If you use the lamp beyond its service life: - you may notice a reduction in the colors and/or brightness of the picture, at which time you should replace the lamp unit; and - the strength of the quar tz glass in the lamp will be reduced and the lamp may rupture. If the lamp ruptures, the TV will not operate until the lamp unit is replaced. Here is more info: LED Indication Condition Solution: 1) Green lights solid; Red blinks at 0.5-second intervals. 2) Green blinks at 0.3-second intervals; Red lights solid. 3) Green and Red blink at 1-second intervals. 4) Green is off; Red blinks. 5) Green and Red blink three times. The lamp unit door is not seated properly.The lamp is not working properly. The lamp is not working properly after the eighth automatic restart (see item#2). For service personnel only. An abnormal temperature increase has occurred. Turn the POWER OFF and unplug the power cord. Review ?How to replace the lamp unit? on pages 57?59 to ensure that the lamp unit door is installed securely. If the problem persists, contact a Toshiba Authorized Service Center. The TV automatically will try to restart itself eight times.Turn the POWER OFF and then ON again. If the problem persists, replace the lamp unit (see pages 57?59). If the problem still persists, contact a Toshiba Authorized Service Center. Turn the POWER OFF: and unplug the power cord. If the problem persists, contact a Toshiba Authorized Service Center. Do not block or cover the slots or openings in the TV cabinet. If the problem persists, contact a Toshiba Authorized Service Center. _______________________________________________ Good luck! I hope this helps you out!
Posted on Sep 07, 2007
bluegreenash
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
SOURCE: Cleaning inside lcd panel for toshiba r15 s829
Remove battery then remove trangular black tabs (2) at the top of the screen. Then remove square silver tabs (4) at the bottom of the flip top. This can be accomplished with either a push pin or sharp knife just get under one corner and peel off. They are just thin pieces of plastic with and adhesive backing. Remove the screws underneath ( 6 in all) with a small screwdriver. Run your fingernail around the entire outside edge of the flip top to pop off the plastic front with screen. Wipe off LCD and inside of the screen with a soft damp cloth; do not spray anything directly on to the LCD. Reverse the above steps and if you were careful you can just reattach the plastic tabs over the screws.
Clear view again!!!
Posted on Mar 27, 2009
SOURCE: Sony CDX-M850MP Remote wont work when front panel closed.
The problem is the flexible wire strip that cracked. I just had the same problem. A guy has them on auction on e bay. Type in model number and flexible replacment for search.
Fix by.
1. Unscrewing 2 the two screws that connect faceplate to motorized flip bracked. One on each side.
2. Unscrew the screws that are connected to the back plate. Plate directly behind faceplate with Blue LED.
3.Unclip backplate by sliding Deck out 1 inch. Two clips on each side.
4.Unclip the waferboard/circuit board from the back plate.
5.Remove Flexible wire band that connects the faceplate to backplate.
6.Attach new flexible wire band to deck then to face.
7. Reclip everything, Rescrew everything.
Whalah it is fixed.
Posted on Apr 09, 2009
  • 142 Answers
SOURCE: 62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Posted on Mar 15, 2010
How do I get rid of all these zeros moving accross the display
This problem maybe is caused by a software bug and
can only occur if the Line-in NR is turned on in
DISPLAY > VIDEO menu before starting to
record, Unit hangs after trying to record from Line
Input to DVD
If the "OK" or the "Return" button on the
remote is pressed at this time, the unit will
hang and the front display shows scrolling
"ooo...".
Unit can be recovered by pressing the RESET
button on the front panel.
to correct it Download the improved firmware from
Panasonic Web site and update the
unit
May 13, 2013 | Panasonic DMR-EZ28K DVD Recorder
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba DVD/Video Cassette Recorder DKVR60KU Logo
306 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
