Question about Oreck Micro-Sweep Blade 7500901
How do you replace the mico-sweep blade that is broke
The mico-sweep blade is broken to three peices
  • Oreck Master
  • 932 Answers
Most of the time, you cannot get a new one of those blades unless you replace the entire base plate. Depends on the model that you have. I would suggest checking with a local vacuum repair shop to see if they can help you. If you go to Oreck's website Oreck Store Locator you can see if you have one near you.
Posted on May 16, 2015
How do i remove the wheels or whatever i need to remove to get the hose peice out it was held by a plastic peice tht i wanna replace
Remove the wheels, axle, handle latch and spring. Then try to find someone that still has a power head elbow for an old hoover. I can check to see if they still have any if you call me. 1-800-353-4677 tomorrow
Jan 29, 2014 | Vacuums
I have a bissell steam and sweep. when I am finished using it water still leaks from the bottom leaving water?
  • Drain the tank after each use.
  • It either has no shut off valve or a broken one when not in use.
  • If its new return it and see if new one leaks or not.
Nov 13, 2013 | Bissell Steam and Sweep Hard Surface...
Suction has diminished since I purchased it a year ago. Hose is not blocked, Cannister is empty, and plastic filter above cannister is clean. What could be the problem?
Three possibilities I can think of:
1. Leak/holes in the hose.
2. The fan blade are worn down or broken. The more they're worn down, the less suction.
3. The motor itself is dirty and/or wearing out.
Any one of those problem would call for a replacement of the part involved, or the vacuum itself. It could also be a combination of any of them.
Dec 14, 2010 | Bissell Versus Bare Floor Vacuum
When i am vacuuming my carpet....it sucks the dirt up when i am pushing it forward, but when i pull it back, the dirt comes back out on the carpet
This is due to a loss of suction. The roller brush sweeps the dirt to the hose area, but with no suction, when you pull the vacuum back, the brush just kicks the dirt back out. This is most likely due to a clog in part of the hose system.
You don't mention whether it's a canister or upright, but check all hoses and tube.
It can also be due to a full bag or clogged filter. Another cause could be a fault in the switch or wiring that turns on the power nozzle (only if it has a separate motor) but not the vacuum.
The fan blades could be broken or worn, which would allow the vacuum to run, but with no airflow/suction.
Or most costly, the motor is worn out and no longer working.
Nov 03, 2010 | Vacuums
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
Sweeping part of the vacuum stopped spinning.
Is the belt stretched or broken? There needs to be a (not-stretched and not broken) belt connecting the rotating brush (agitator) to the motor pulley on the vacuum.
May 05, 2009 | Kenmore 31913 Progressive Direct Drive...
Hoover agility steamer lower hose broken
take the handle screws all out and take the black peice where the hose attatches to loose. then pry handles apart gently and the hose peice will be able to be reached. not easy but can be done.
Feb 21, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Brush won't turn while sweeping
Does it smell like anythings burning if it's on for a while?
It could be that the belt is just stretched out and not keeping enough tension on the brush while its on the carpet. Once you tilt the vacuum up, there's no more friction, so it spins freely. I've had a few that did that.
Oct 26, 2008 | Bissell Vacuums
Oreck Micro-Sweep Blade 7500901 Logo
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
