Question about Sony Playstation 3 (PS3) Console
My ps3 wont connect to the playstation network. it connects to the wireless fine but the network connection request keeps timing out
    Problem Solver:
  • 7 Answers
Ben
Posted on Jul 14, 2009
  • aaaa aaaa Jul 14, 2009
    you simply need a better signal!
5 Suggested Answers
josh1856
  • 105 Answers
SOURCE: cant connect to playstation network
connect ps3
hope that helps. if not post again and we can troubleshoot some more
Posted on Jan 26, 2008
splintellz1
  • 37 Answers
SOURCE: how do i reset our wireless network setting on my playstation 3?
On the back or side of your router their is a button that resets it to the original factory settings. Hold that button down for 5 or more seconds then release it.
Everything should be back to normal, also you will have to reconfigure that router
On the bottom of the router the user name as password might be------> user= Admin Pass=password
Posted on Jul 02, 2009
ElectronicRe
  • 37 Answers
SOURCE: error 80031606
turn on your ps3 from the back switch but leave it with the red light on (on the front).
now press the power button (where the red light is)and hold it, you will hear the initial single beep then you will hear a second single beep after that you will hear a double beep. when you hear hear the double beep release. You may have to do this twice. First time doesn't always work
a menu with 6 option will appear. select option #3
when the ps3 comes back up. repeat steps but now select option 2
no game data or trophys will be deleted
you will have to setup again.
Posted on Oct 23, 2009
hmerchant110
  • 7191 Answers
SOURCE: my playstation network keeps failing in my ps3 and
This is a worldwide issue with the Sony Network today which might be due to system maintenance and upgradation.
Sony is working on the problem and the problem will be rectified soon. Kindly wait for further announcements from Sony. Your system should work normally when the issue is fixed.
For details and status updates, click here
Thanks for using FixYa.
Posted on Mar 01, 2010
My playstation wont download and if it does it takes a long time
Seems like its not getting a good connection to the server. Trying restarting you wifi server
Sep 21, 2012 | Sony Playstation 3 (PS3) Console
Cant connect to psn. But i can to internet. :(
One reason this may be happening is having the media sharing option on. Some routers can't handle all the requests the ps3 sends while having this option on. You're using a wireless connection right?
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 help!
I think this is caused from your new ps3 not having the connection to your wireless box, try inputting the wireless key(back of the wireless box) into your ps3 on Network Settings. Hope this helps.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont let me sign in to PlayStation Network
It has worked before, right? Have you checked your network? Are you wirelessly connected? Can other computer go on the internet fine? Try resetting your wireless router and cable/dsl modem and then resetting your ps3 to see if that works.
Hope this helps,
Bill
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 bluetooth connection
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
