Question about Dishwashers
Smeg Dishwasher semi integrated, bought in 2001/2002
Hi there
           We have a crack in the plastic bracket that is attached to the underside of  the top tray, which  holds the rotating handle that sprays water onto the cutlery below.
As a consequence, the dishes are not thoroughly washed as previously.
Can we get that part, and is it easy to replace?
We also need a new cutlery tray.
Thank you
Arthur
PS The manual we have does not have a serial number, nor does it address this problem.
  • 4,102 Answers
Yes tehse can both be replaced but you will have to use your search engine to find out the contact no for the make of dishwasher or if you go to any repair shop thay sells fridges and freezers and dishwashers these will also order the parts in for you and they should also have a order book with the part no in for you to contact them hope this is some help sorry o couldnt tell you any more i got my spares through a repair shop took couple of days but cheaper than buying ne dishwasher
Posted on Oct 31, 2007
Whisper quiet plus
There should be two thin metal tabs on top of dishwasher that extend out and attached to the underside of counter top. They may have been bent back or they are broken off
Mar 24, 2014 | Whirlpool Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
How do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Sep 02, 2012 | Smeg Dishwashers
How do you side mount a bracket in the LG dishwasher? The model number is LDF6920ST. We have a granite countertop, so we are trying to mount the bracket inside the dishwasher as the manual indicated. ...
There is a hole on each side of the dishwasher about 6" down from the top and in-front of the rubber door seal, with round plastic covers in them. Just pop those covers out and the side mounting brackets align with those holes and the screws go into the wood frame. You may have to put some small blocks of wood on the wood frame to take up some of the space between the side of the dishwasher and the cabinet frame. Be sure to drill pilot holes for the screws to avoid splitting the wood.
Jan 22, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
As the dishwasher was finishing its cycle - up to drying - three small explosions occurred accompanied by the smell of burning. We turned the power off. Is it repairable or is it time to get a new...
well its up to u about getting a new one but it sounds like the heater element burnt into but yes it is repairable but at what cost unless u can repair it your self u may be able to save money on repair costs if u have to call a repair man then it may be more cost efficient to just get a new one since that unit is that old
Jan 21, 2011 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
