Question about Wahl 8451 Magic Clip Hair Clipper
Wahl clippers manual
Where do the two springs go? pls help...
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
rick_stokes_
  • 61 Answers
SOURCE: loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Posted on Sep 27, 2009
philschneide
  • 448 Answers
SOURCE: Noisy wahl hair clippers
If your clippers are the magnetic type (rather than pivot or rotary) they should have a large screw on the side for adjustment (I think the screw you mentioned). The standard adjustment of the screw is to turn it in while the clipper is running until the sound of the clipper increases substantially. Then turn the screw back out, slowly, until the sound decreases again. Turn another 1/4 to 1/2 turn.
Unless something else is wrong, this should take care of the problem, along with proper oiling of the blades.
I hope this helps you.
Posted on Oct 12, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
The wahl peanut has the same motor than wahl tid bit?
the tid bit and the peanut are the same clipper. you will find the tid bit clipper at shaveroutlet.com. See link below
http://shaveroutlet.com/wahl-tid-bit-professional-compact-clipper-trimmer.html
Jun 22, 2010 | Wahl 8685 Hair Trimmer
I took the bland off of my wahl model 9860-1101. And the pin spring came out and I don't know how to put the pin sring back in. How to I put it back together?
Your best bet is to send it to www.mannyssharpening.com Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 13, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Need wahl stable pro parts
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
815-625-6525
Nov 23, 2009 | Health & Beauty
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Wahl 8451 Magic Clip Hair Clipper Logo
63 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
