Question about Panasonic KXDT343 Phone
Phone is restricted to make outside calls. How do I unrestrict this phone?
Cannot make calls to the outside
Restricted
you can get the Restriction code for your Nokia 7360 phone from SimpleUnlocking.com and unrestricted your phone from Network lock easily.
Oct 12, 2013 | Nokia 7360 Cellular Phone
Can't make an outside call, phone says "restricted
contact to your service provider for lift restricts from calls
good luck
Mar 02, 2011 | Samsung Prostar 816 Phone
Can we make it so the phone can receive calls but not make out going calls?
You can, but you need access to Installer level programming. I'm not going to give you detailed instructions here, because any fool can do the reverse and UNrestrict a phone with the same instructions, but system program 500 and 501 sets day and night restrictions on a phone. Setting the COS to 7 lets the phone dial 0, intercom, and, by programming, System speed dial numbers.
COS 8 allows Operator only (internal operator).
By building tables, you can actually program different restrictions and exceptions for COS 2-6. There's a fairly comprehensive discussion in the Panasonic Features Manual of your TD 816/1232 manual.
Carl
Feb 18, 2011 | Panasonic KX-T7431 Corded Phone
How to enable all extensions to dial 0 (for calling mobiles) after getting an outside line with this facility
When the system was installed, someone programmed it to restrict first digit 0, or the telco is restricting it. That same installer has the ability to reprogram the system to allow some or all digits. At the very least, you might be able to put allowed mobiles in system speed dial and that may unrestrict the number.
Carl
Jan 08, 2011 | Panasonic KX-TA308 Phone
Want to unrestrict my nokia 2330 have ime just need restriction code
This will be worked out between your service provider and you ... Please give them a call ...
Jun 02, 2010 | Nokia Classic 2330 Cell Phone
My phone is restricted. It says "ready" on the display. How do I unrestrict it?
You are having an issue with your service. Nothing you can do manually. Call Nextel. If your carrier, "Nextel" isn't present on the display then you have a service issue. Ready means that an emergency call will work but you can't make or receive calls.
Apr 15, 2009 | Nextel i355
Sanyo 2400 - Parental Control Reset
Call your service provider. If it is Sprint, we can walk you through accessing the unlock code on most phones. I always recommend trying the last four of the phone number or 0000. Hope this helps!
Dec 31, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
Nokia 5310 phone restricted
phone restricted nokia 5310 SOLUTION
Jul 31, 2008 | Computers & Internet
Panasonic KXDT343   Phone Logo
56 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
