Question about Nilfisk Family Vac Bagged Canister Vacuum
Poor suction in my nilfisk GD 1005
Suction has got weak in past week
No suction
If you have got little or no suction in your Gm90 then almost always the problem is going to be in the filters.
The main Cotton Filter is part number 61588200 it is the likely culprit if you have had a burst bag or something similar.
Aug 06, 2012 | Nilfisk Vacuums
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
Fuller brush model fb-dcc has poor suction
All these responses are BS. I have an FB-DCC...AWESOME suction. When's the last time you CLEANED YOUR FILTERS?
May 05, 2012 | Vacuums
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Nilfisk A300 Suction problem
Mate - don't know if this will help - I had the same symptoms - saw your question through google - no answers, then I moved the red slider button on the top of the vacuum and hey presto! It has adjustable power. Man I felt like an idiot!
Jan 30, 2010 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Poor suction
Either you have clogged filters, or the motor is weak, you could check the carbon brushes, otherwise replace the motor.
Mar 28, 2008 | Vacuums
Nilfisk Family Vac Bagged Canister Vacuum Logo
21 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
