Question about Samsung Jet S8000 Cell Phone
I have active password display lock/ how to remove
How to remove this lock in display
I need help unlocking my zte t185
WAKE UP FROM SLEEP MODE • Press the Power key to activate the display. • Long press on the screen to unlock. • You can pinch out on the lock icon to get quick access to Phone, Email, Messages, Audio, Camera and Calendar apps. SWITCH YOUR HANDSET TO SLEEP MODE Press the Power key to activate sleep mode. Sleep Mode activates automatically with the timeout set from Options > System settings > Display > Sleep. TIP If you set an unlock pattern, PIN or password you need to enter it to unlock the screen. If you forget your pattern or PIN use your Google Account password to reset the phone. This will only work if you register a Google account with this handset.The above instructions ARE NOT for the FRP lock, which requires the Google Account information that the device was set up with. Were you asking about the FRP lock?
Mar 24, 2018 | ZTE Cell Phones
Television question
That means The child lock has been activated.
I'll let you know if there is any solution for that.
Apr 09, 2008 | Haier HTF27R11 27" TV
How to bypass iPhone 4 icloud passcode
iCloud password should be the same passwords as your apple id
Jul 11, 2014 | Apple iPhone 4 Black Smartphone
How to remove Windows 7 password to let Toshiba laptop boot from hard drive successfully?
Windows operational system locked always leads to Windows 7 not boot from hard drive completely. Actually, that just need you type correct password to login Windows 7. However on this occasion, only password reset disk or password recovery could help us remove locked Toshiba Windows 7 password.
1. Remove Windows 7 password with reset disk
When you type incorrect password, the window will prompts you that Reset password. Click the link to begin password reset with disk.
Following the password reset wizard, you can easily reset Windows 7 password with boot disk.
2. Remove Windows 7 password with password recovery software
Step 1: Download Windows 7 Password Genius from Internet.
Step 2: Install and run it on accessible computer.
Step 3: Take blank USB disk and insert it into accessible computer for password reset disk burning.
Click "Begin burning" to create a Windows 7 password reset disk. Exit USB disk from the computer when you see the message "Successfully burning".
Step 4: Plug USB reset disk into locked Windows 7 computer, set it boot from USB device.
Step 5: When Windows 7 Password Genius program runs in WinPE, choose accounts and click "Reset password" to remove these accounts password to be blank.
Reboot locked computer and it will boot from hard drive successfully, without any login password anymore.
Aug 21, 2013 | Computers & Internet
I need to reset the password for my zenith tv model # C27J28B
If you did forget the code to release V-chip to this TV, there is no other way than contact its authorised service center. If you want to unlock the child-lock to certain channels:
Press or to display the password entering mode.
Press MENU, then press or to display the (LOCKS) menu.
Use the number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
Press or to highlight CH LOCK and press or to display
the CH LOCK menu.
Press or to highlight CLEAR and clear all channels from the
list of locked channels. Press ENTER.
5
6 Press EXIT to return to normal viewing.
Jul 04, 2012 | Zenith Televison & Video
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
I forgot password on samsung sgh j210.. it as
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Mar 28, 2009 | Samsung SGH-J600 Cellular Phone
Laptops Acer e lock activated / password unknown
Fastest way slick and reinstall. That's why I never in 25 years of computer support never enabled passwords that deep. Some system have a hardware reset buried inside but it takes a tech to get to it. Some time removing the CMOS battery will do it. It would be easier to hack the OS and get into the Admin password than a hardware passwork.
Jan 06, 2009 | Computers & Internet
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
Input password
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 12, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Samsung Jet S8000  Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
