Question about Propur Proone-d Dual Domed Filter Elements 3 Pack One Size Fits All
Propur proone-d filter cleaning produces black solution
Clean filter
My toyota hiace with 2kd engine is producing a cloudy black smoke and hard stating what could be the problem
Black smoke means too much fuel .
Have you changed your air filter or is it clean. A dirty air filter will flood your engine.
Is your choke working properly?
Could be your carburetor float is sticking.
Not sure but there are computer sensors in some makes that could cause flooding if they are not working properly.
I am sure there are other things that could be the cause but you can start here.
Apr 17, 2017 | Toyota Cars & Trucks
The throttle body on my 5.4litre 99 ford truck has black gewy gummy gunk in it what's the cause of that
thee will always be oily smoke coming back past valves from the pcv valve outlet when the engine is stopped
if you have a problem air filter then any fine dust will mix with that vapour and produce what you have
check the air cleaner and entire air filtration system for leaks including the air filter
The latest news from all manufacturers is , air filters are no longer cleaned but replaced with new units
May 11, 2016 | Ford Cars & Trucks
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
I have renewed the black ink cartridge but the printer does not print and i want to clean the print head but do not have a clue and i am very unclear on my computer so need step by step help the printer...
there is a utility in your printer software , using that you can clean the head of the printer, if this does not solve your problem use the alignment option from that utility
Jul 29, 2011 | Epson Stylus C66 Inkjet Printer
I have an HP Officejet 5610 All-in-one which is producing a black line which is approximately 1/4" wide down the middle, top to bottom lenghthwise. I have changed the toner, cleaned the glass and...
First thing you have to do is run the clean print cartridge utility. You can find it in the Printers and Faxes in the Control Panel, Right Click printer Icon and select Properties and Click on Printing Preferences . Click the Services tab, then the Service This Device icon. Select Clean the Print Cartridge(s). If still the same thing. Clean the cartridge itself by using clean cotton swab dipped in clean distilled/ filtered water. Check this image: c00217862.jpg 1 - Clean in the cross-hatched area only 2 - Do NOT touch the nozzle plate 3 - Do NOT touch the copper-colored contacts Do this on both cartridges. Let the cartridge dry for five minutes or use a new swab to dry the cleaned areas before you reinsert the cartridges. If problems persists, change the cartridge.
Mar 30, 2011 | HP Officejet 5610 All-In-One InkJet...
Slow Engine Pick Up
Check if the air filter is clean,if it is block,the engine will not produce enough power,you will see a black smoke coming out from the exhaust pipe,change the fuel filter also.
Feb 25, 2010 | 2005 Ford Five Hundred
I've acquired a plant with a Triton SP-710 sand filter (Pac Fab Filter, 75 gpm rated flow) that is 25 years old -- it is supposed to be cleaning up bearing lubricant water, but a significant amount of grit...
For an old filtering system, there's no other way to clean
it quick but to backwash it with the pump that is hooked to it. Or you can clean and have it rehab by opening it
up which will of course produce a better result. Just
send your e-mail comment for further assistance.
Oct 10, 2009 | Plumbing
Black smoke from exhaust
black smoke is to much petrol ,check the choke to see if it's sticking if it got one also check air filter to make sure it,s clean. hope this helps other wise take it to a jag expert.
Jun 26, 2009 | 1995 Jaguar XJ6
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Propur Proone-d Dual Domed Filter Elements 3 Pack One Size Fits All Logo
66 people viewed this question
Top Propur Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Propur Fish Expert? Answer questions, earn points and help others
