Question about Magnavox DV220MW9 DVD Player VCR
No picture for vhs
We do have sound but no picture
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
Have a samsumg 4600 combo dvd/vhs plays vhs with good sound and picture, dvd only has sound and no picture
need to check the video audio output connectors sounds like it hooked to and output that is only for the vhs
Jul 07, 2009 | Samsung DVD-V4600 DVD Player/VCR
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
VHS side doesn't have pictures
the connection from your player to TV is only single output not separated DVD and VHS. If there is picture when used on DVD then you should be having problem with your VHS player. Question.... is your unit new? Is this the first time you encounter this problem? what is the brand of your player?
Jun 28, 2008 | Televison & Video
Dvd/cd player Video Cassette player
try cleaning your video head, use a VHS tape cleaner.. use a wet type cleaner
May 04, 2008 | Philips Magnavox DVD/VCR Dual Player
My dvd has sound and picture, no picture but sound on vhs
try cleaning your VHS head, use wet type VHS cleaner cassette
May 04, 2008 | Televison & Video
VHS - Sound but no picture
sounds like the video head is dirty, you can try a head cleaner, sometimes tougher dirt on the heads may require manual cleaning of the video head. good luck
Feb 28, 2007 | Panasonic DMR-E75V DVD Player/VCR
Magnavox DV220MW9 DVD Player VCR Logo
61 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
