Question about Water Filters & Coolers
Hidrogenia 700 water filter machine not getting cold
THE WATER FILTER MACHINE DOES NOT MAKE THE WATER COLD
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
  • 67 Answers
SOURCE: Low Cold Water Flow into Machine
the water inlet valve has to be replaced,its the part where you seen the screen ,where the hose hooks up to,theres a cylinoid that opens and closes and lets the water come in,your cylinoid is no good,but you change it as one unit,and its called water inlet valve,easy fix you can do your self,if this helps please vote me a fix ya
Posted on Jul 15, 2008
  • 15 Answers
SOURCE: FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: Cold water just drips, hot is fine, good pressure.
turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Posted on Apr 19, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: cold water input only works intermittently
Replace the water inlet valve. You can get one at your local appliance store. Or at repairclinic.com. Easy to replace and can be done by just about anyone
Posted on May 18, 2009
I have a lime.stoppage in the washing.machine or hose, where do I start? It is not.the.wall faucet. I tested it.
check/ replace the inlet solenoid valve unit in the machine
if it is faulty or not getting power then the water will not flow into the machine.
simple test is to change the hot water hose to the cold water tap and use hot water setting with the cold water tap on
if the water flows then it is the cold water solenoid
Mar 18, 2015 | Washing Machines
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
Broke the plastic screen that goes to the cold water inlet valve?
The broken bit of filter has probably got stuck under the rubber diaphragm in the inlet valve. You will have to strip the inlet valve and remove the piece. There should be 3 or 4 screws holding the valve together. Make a note of how it comes apart. There will be a spring, a metal plunger and the rubber diaphragm inside the valve.
Apr 27, 2017 | Maytag Washing Machines
Hi, The cold water is entering the machine very
Did you clean the filter? There is a filter in the inlet, a little filter that can be removed with a pair of pliers. Rinse it out and put filter back in its place. I think it would not even matter if you leave the filter out. Hot water filter is not blocked because it is not used as often as the cold water one. Clean both! I noticed a big drop in water flow if filter is dirty.
Sep 14, 2011 | Samsung SW62ASP Top Load Washer
No cold water enters tub. Everything gets washed hot no matttter what the setting.
You water line filters may be stopped up. This happened to me once and I unscrewed the two hoses next to the machine and looked. There was a filter that I could remove, made of hard plastic. I took the filters out of each hose and screwed the hoses back on the machine, without the filters. It worked for years. The other thing that I have done is I once had a machine I couldn't get unclogged and the line didn't work for my cold water so I turned off my hot water and I took the hot water hose and put it to the cold water tap. My cold water came into the machine by the hot water hose. I used it for years afterwards. I just had to wash everything in cold water.
Jul 16, 2011 | Siemens WFXD5200UC Front Load Washer
Cold water is not filling the machine like it should. it comes out in trickle.
There is usually a filter at the cold water inlet and probably is clogged if the cold water supply is usually dirty or bore hole water. Remove the filter and clean it
Other cause is that the cold water pressure is too low.
Oct 05, 2010 | Amana NTW5500TQ
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Washing machine will not run on cold water ...will not fill or operate when cold water is selected. Temp selector switch or fill valve??
Check the water filter to see if it is possibly blocked. Shut-ff off the water valve on the cold side, then disconnect the cold water hose to get to the cone shaped filter. Pull the filter out and see if it is blocked.
Aug 21, 2009 | Washing Machines
No cold water will enter machine but not water
Turn off the cold water.
Remove the cold water hose from the washer. Clean out the filter screen in the water valve. Re-attach the hose and turn the water back on. If you get no cold water replace the water valve.
May 01, 2009 | Roper RAS8445KQ Top Load Washer
Our washer dryer is leaking water after the drying cycle. Everything seems to be fine just after the cycle has finished but in the morning the floor is covered in water. It seems to be coming from the...
Hi. I take it that the machine is of the condenser - dryer type?
In these machines, during the drying cycle, warm air is circulated inside the drum and a cold plate is either splashed with cold water or has cold water running through it, causing moisture from the clothes to condense on the cold plate - just like moisture in a room condenses on a cold window pane on cold days.
If your machine is continuing to fill up slowly with water after it has been switched off, then I would suspect the cold water inlet valve isn't closing properly. This is likely due to a build up of grit inside the valve.
If you turn off the cold water supply you will be able to remove the cold supply pipe from the machine and - hopefully - see some of the grit on the filter gauze. The grit possibly causing your problem is already inside the elcetically controlled inlet valve, so it may need to be removed and cleaned or replaced.
You should be able to check if this is the problem by just turning off the cold water supply to the machine. No supply means no water can get into the machine, so it shouldn't fill up overnight.
Before removing the filter down at the bottom of the machine you could turn the machine on to a spin or pump out cycle - that way you shouldn't need wellington boots when you removed the filter :-)
Hope this helps a bit. If not, add a comment and I will try to help you further. D.
Jul 09, 2008 | Hoover Washing Machines
Water Filters & Coolers Logo
118 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
