Tachiometer error candy
Having trouble with king games on Facebook
https://care.king.com/en/candy-crush-saga/e-error-error-1034-ccs-error-message-something-went-wrong-after-a-saga-api-call-https-candy watch the video
Jul 16, 2016 | Apple iMac 24" Desktop
Candy washing machine grando gc42d error 3
machine is not draining or not draining quick enough and times out on drain check filter at the bottom rhs
Jan 25, 2015 | Candy Washing Machines
Candy error code e05
The error code E05 means the temperature sensor has gone bad.
Aug 24, 2014 | Candy Washing Machines
Candy grand o evo error eo3
Not drained in time allowed - washing machine fails to drain water
·Check that filter is not blocked or obstructed
·Check drain hose is clear of any blockage or obstruction
·Check wiring to drain pump
·Check drain pump is not defective
·Check level sensor or switch
Check wiring to level sensor
Jun 04, 2014 | Candy Washing Machines
Candy Crush Saga "got this error message "[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]]"
[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]][CCS error message: A saga api call went wrong.]
Candy Crush Saga on Facebook Facebook
Aug 08, 2013 | King.com Facebook Apps
Error code E08 on candy washing machine
Hi.
E08 means that the motor has failed (tachiometer error). Shut down your machine and disconnect power cord for five or ten minutes. If that is not enough to clear the code call the support number listed in your owner manual.
Regards.
Ginko
Dec 15, 2011 | Washing Machines
Error code E1 for a Candy cdi454-s dishwasher....any ideas ?
Error code E05 for a Candy CO 5100d dishwasher....any ideas ?
Oct 18, 2009 | Dishwashers
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
