Printer problem printer asking to remove and check cartridge. I did all that and is still asking the same
  • 1 more comment
  • chola Oct 31, 2007
    It's just telling me the error. The cartriged is baerly new and it just stated telling the error.
  • pozman6 Nov 05, 2007
    I have refilled my ink cartridge and the printer is giving me an error message concerning the right cartidge is in incorrectly. I cannot get rid of the message or get the printer to work.
  • ginamurt Dec 28, 2007
    I replaced both cartridges and did test page. It printed fine but when attempted to print other items, I get check cartridges. pls help
  • 328 Answers
This is a common problem if you refill the ink as opposed to getting a new cartridge because the circuits on it start to fail after some time. If its newer, there is still a possibility that it's defective. Does it print or just keep telling you the error?
Posted on Oct 30, 2007
I have a X5470 Lexmark printer and it keeps telling me there is an alignment problem and is asking me to remove tape from the cartridges. There is no tape there that I can see.
It could be the cartridges in the carrier. Open the printer cover. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. If all is well, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first then close the cover. Check for any errors. Then, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. Or you can try to insert a different known working cartridge to determine if the other is faulty.
May 20, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer is asking me to check replace colour cartridge, i have done this but still the same issue and i obviously can't do anything with it. thanks
Issue After you install a print cartridge, the following message appears on the color graphics display: Cartridge error: one or both cartridges are not intended for use in this printer . The device will not print. Solution Step one: Remove, inspect, and reseat the cartridges The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridgec00484998.gif
  4. Slide the cartridge out and inspect it: CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tapec00211538.gif
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figure 4: Sliding the cartridge into the carriagec00484999.gif Figure 5: Pushing the cartridge into placec00485000.gif
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
Remove and Check Color Cartridge keeps appearing. I have changed color cartridge and message still appears.
is a non-original or defect color cartridge. ask for change cartridge to original. If still continues, ask for a new printer the cartridge bruned your printer board.
Jul 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
7310 ask to control/check bla/wh cartridge. Replaced with new one and keeps on asking to replace. How to resolve?
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Where is the Printer Cover on the Canon Fax 8500? The fax is asking to Check the Printer Cover.
The printer cover is the cover that you open to remove the cartridge. Open it and check that the cartridge is inserted correctly. Remove and reinsert cartridge then close the cover. Check all around the m/c to make sure all doors are closed.
Sep 24, 2009 | Canon FAXPHONE L80 Laser
OKI C3530N
Take cartridges out of the printer.
Close cover.
Unplug printer for 30 minutes.
Reconnect printer to power.
Printer demands cartridges.
Reinsert cartridges as demanded.
Oct 31, 2008 | OKI C3530N Color MFP Printer
My HP printer is displaying the following message: Remove and check cartridge. I have removed and checked the cartridge, even replacing the black cartridge and still get the same message.
One of the printer cartridges had a expiration date of 2008/9/2. I replaced the cartridge with a new one and the printer now works. Thanks for asking.
Sep 28, 2008 | Office Equipment & Supplies
ASKING INSTALL COLOR CARTRIDGE
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Sep 24, 2008 | HP DesignJet 750c plus InkJet Printer
165 people viewed this question
k24674
jasbo
jasbo
