Question about FreeMotion 730 Treadmill
Fan stopped working
The fan on my treadmill stopped working.
Why doesn't start button start it?
Hi I had the same problem, 1st I checked the fuse and eventually needed to replace the console mat....
Mar 22, 2016 | Proform ZT4 Treadmill with LCD Window...
The fan on my Horizon T202 stopped working . Any Suggestions?
if the fan still turns by hand it is likely the temp sensor or power source check if there is a fuse or review a manual for location of the sensor.
Jul 19, 2014 | Horizon Fitness T202 Treadmill - Sport...
My fan won't work on my nordictrack 4400R treadmill. What should I do to get it working.
please test the voltage in the motor fan with DVOM. IF There are voltage , and the motor is NOT running , replace it.
However you must tight very well all the connectors. Test the fuse in the treadmill see the block diagrams attached for troubleshooting.
God bless you
Jan 09, 2013 | Exercise & Fitness
Mi fan won't work on my nordictrack 4400R treadmill
test the input voltage motor fan, If there are replace the fan motor.
However you must tight all connector, test the fuse+c.breaker.
See the diagrams attached for troubleshooting guide.
God bless you
My treadmill will start and you can increase speed and incline but fan will not work and you can not decrease speed or incline. And I can not stop the treadmill. I have to emer. stop.
I'm not sure if this will help.
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
Hope this helps,
Kurt
Jan 21, 2011 | Startrac Fitness Products Star Trac Pro S...
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Ironman M2 treadmill starts but then stops right away
Most treadmill will run for a second or two but stop if the speed sensor don't pick up a speed. If the treadmill was moved there is a good possibility that the sensor is off line. Not 100% fimiliar with this particular unit but if you remove the motor cover, these are the usual places for speed sensors. The front roller- the side where belt come from the motor. The other popular place is on the motor fan. The sensor has either two or three wires with the sensor at the end. On the roller, the sensor needs to be close enough to pick up the magnet on the side of the roller. On the fan make sure the teeth are clean and sensor has a good connection. Hopefully one of these will do it for you.
Nov 17, 2009 | Exercise & Fitness
FreeMotion 730 Treadmill Logo
Top FreeMotion Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
