Question about GE GSL22JFR Side by Side Refrigerator
GE side-by-side TFX26ZP
My wife and I just bought a GE side-by-side TFX26Z used. The seller said it worked fine and we had no reason to doubt her because she had apeared to be using it up until recently. After transporting it and cleaning it for an hour and a half, we plugged it in and then hooked up the water hose. The lights work and the water works, but it doesn't seem to be getting very cool or cold in either the fridge or the freezer respectively. It's emitting a steady hum so it sounds like it's working but I guess I'm just anxious to know that it works after all the hassle of moving it and cleaning it. There's a decal in the fridge that reads "Allow 24 hours for adjustments in temperature" so I suppose the refrigerator won't be open for business until tomorrow. I admit I'm in uncharted waters with this as I've always rented in the past and my biggest battles have been with tundra-like ice in freezers. I just really wanted to go buy some milk and ice cream. Here's hoping waiting is the answer. Tell me I didn't just buy a inconveniently configured cabinet.
  • 149 Answers
If the compressor is shaped like a coffee can and not like a cantalope then yes..you probably just got took. I had to replace many "rotary" compressors on GE/Hotpoint refrigerators built in 87-88. I hope i'm wrong. good luck :)
Posted on Jun 15, 2009
This is now the 3rd GE to die on me in 10 years. Model is PEB2060dm1ww. Its a built in microwave Last night my soon cooks his dinner OK. When my wife went to cook her artichoke.. all seemed fine as the...
if out of warranty you can try a simple "fix" . some microwaves are made with a simple fuse on the inside of casing- should be able to remove cover with 4-6 screws and then locate fuse- DO NOT TOUCH ANYTHING ELSE! If in doubt replace the whole thing.
PS- if dusty inside ,use canned air(for computers or cameras)
May 02, 2011 | GE Microwave Ovens
Ice maker not working Water works fine in the door. (GE Profile side by side)
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfs4
May 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Re GE TFX26ZP sid by side fridge Evaporator coil keep ice on it
the defrost thermostat should be clamped onto the evap coils..defrost timer should be under fridge. If this is a newer model, it might have an ecm ( comp control) on top of the compressor..
Sep 21, 2009 | GE GSL22JFR Side by Side Refrigerator
Everything works except when used today no heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Feb 19, 2009 | GE JVM1430 Microwave Oven
It is possible to delete a lost 4 button remote key chain
Obtain the installation manual. You should be able to find this on Google. Search for Ge Simon 3 install manual. Follow te instructions for deleting sensors.
Jan 25, 2009 | GE Security Simon 3 Wireless Home Security...
Cdj 100s not working
Hi, Marc, your player has lived his life, you have to bought a new lens and install.
Djajay
djajay@inbox.com
Jan 24, 2009 | Pioneer CDJ-100S CD Player
GE photo phone - CID not working in India
I doubt it will work, as there are differences between the codes that US phones expect for caller ID and what India is sending....
Sorry, but that wont work.
Jan 02, 2009 | GE 29273GE2 Phone
GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Dec 16, 2008 | GE JE1860 Microwave Oven
We bought a GE Freezer last week and had it installed 7/8/08. Today (7/09/08) the sides and top are extremely hot. Is this because its a brand new freezer? It's located in our garage.
Talked to the seller at Home Depot who said to wait 48 hrs. Problem should be solved. Also in the handbook furnished by GE they mentioned the reason. Problem solved. Thanks anyway. George
Jul 09, 2008 | GE Refrigerators
GE GSL22JFR Side by Side Refrigerator Logo
211 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
