Question about Honda Garden
Clutch cables transmission clutch cable
    Master:
  • 969 Answers
Replace cable.
Posted on Jul 04, 2015
FIAT PUNTO 2002 MK2 CVT TRANSMISSION SLEEPING ?
if manual transmission and hydraulic clutch --replace the clutch master cylinder
or cable clutch ---replace the cable
or--- replace the clutch ( 1st two options before the clutch as they are cheaper)
if automatic ---change the oil and have the bands and clutch pack adjusted ( use an accredited auto transmission speciliast shop who has experience on your vehicle)
May 09, 2016 | 2002 Fiat Punto
How to replace clutch cable
Hi Anonymous, drain transmission fluid, spray silone spray or brake kleen into top of rubber boot and slide upwards, back off jam nut and screw in adjuster to provide ample free play enough to remove clutch lever and clutch cable end. Remove transmission side cover and ball ramp mechanism, remove clutch cable coupling from outer ball ramp and cable from coupling, then unscrew cable from side cover. Installation is basicly reverse order. Torque side cover screws to 10 ft lbs. Screw out cable adjuster enough so that by pulling on clutch lever with one hand and the clutch cable with your other you obtain 1/16 " to 1/8 " freeplay. Secure jam nut, slide rubber boot back down, and you are good to go. Good luck
Apr 11, 2014 | 2002 Harley Davidson FXSTS Springer...
Where is the transmission cable located on 1998 corolla
Clutch cable? Actually, I think you'd have a hydraulic clutch. If it's cable, it would come out of the firewall, where your clutch pedal operates, and down to the transmission. If it's hydraulic, there'd be a clutch reservoir just beside your brake reservoir on the firewall, with a hose leading down to a "clutch slave cylinder" mounted on your transmission. If you have no clutch, this slave cylinder can be easily bled of air and will gravity feed new fluid to the cylinder.
Oct 25, 2011 | 1998 Toyota Corolla
How do i change the clutch cable on 1987 fxlr
To change the clutch cable, find the clutch cable adjuster and slide the cover up or down so you can get to the adjuster. Loosen the lock nut and turn the adjuster barrel inwards to get as much slack in the cable as possible. Disconnect the cable at the handlebar lever. Drain the oil out of the transmission. Remove the bolts that hold the chrome endcap, clutch release mechanism cover, from the transmission. Look inside the transmission end cover and disconnect the clutch cable from the release mechanism. Note how the "hook" is positioned holding the cable to the release mechanism. Unscrew the clutch cable end from the end cover. While you are in this area, replace the clutch throw out bearing and retainer clip. Take note of the routing of the cable from the handlebar to the transmission. Replace the cable along with a new O-ring on the transmission end of the cable and install a new gasket. Torque the bolts to 100 inch pounds. Adjust the cable adjuster until you have about an 1/8" freeplay at the handlebar grip.
Good Luck
steve
Jul 10, 2011 | Harley Davidson FXDL - FXDLI Dyna Low...
Need instructions on how to install clutch cables on a 02 fxst
First, you have to drain the oil from the transmission by removing the plug located just below the chrome plated clutch release mechanism on the right side of the transmission. Then, take the bolts out of the clutch release mechanism and pull it away from the transmission. Disconnect the link from the clutch release ramp and the clutch lever at the handlebars. Unscrew the clutch cable from the clutch release mechanism. Reinstall the clutch cable in reverse of the way you took the old one out. Refill the transmission with 20-24 ounces of transmission lube.
Good Luck
Steve
May 08, 2011 | Harley Davidson FXST Softail Standard...
Hard to shift gears from shifter. Can go to transmission and shift easily.
loose or mis adjusted shifter cable to your transmission. usually, they break. stretched shifter cable? possible. manual transmission? did not specify. automatic? suggest cable problem,loose cable at some point,look with 2 people to see where the cables jumping during the shifting process. manual? suugest a bad or going bad slave cylinder on the side of the transmission,or low fluid to the clutch master cylinder.is the clutch pedal weak? or just goes to floor and will not come back up? this is sign of leaking clutch master cylinder,bad clutch master cylinder. or both. see brake fluid on ground under the car after you pump the clutch several times? either a bad clutch master cylinder,on the firewall,drivers side,just under the windsheild,or a bad slave cylinder on the side on the transmission under the car on the transmission. suggest that you look for fluid leakage. follow the trail of fluid to the source.
Mar 04, 2011 | Saturn Vue Cars & Trucks
I have a GMC Topkick with a Cat engine. 7 speed manual transmission. Yesterday it seems as if the clutch cable came loose from the transmission. I cannot shift the transmission as the clutch does not...
it is very possible that the operation for the clutch has failed
as to hydraulic or cable , all you have to do is look under the bonnet and see if there is a clutch master cylinder or a cable from the clutch pedal
if hydraulic replace the clutch master cylinder and slave cylinder and if cable replace the cable
better still take it to an accredited clutch and brake service center and have it properly diagnosed service
Jul 12, 2017 | GMC R3500 Cars & Trucks
I am changing the handlebars to 16" ape hangers, need the instrucitons to change the clutch cable and the throtle/idle cables
To change the throttle/idle cables, first you need to remove the fuel tanks so you can get to the carb/throttle body. Loosen the adjusters at the throttle grip on the handlebars. Remove the idle cable first and the remove the throttle cable from the carb/throttle body. Then take the two bolts out of the throttle grip housing halves and carefully seperate them. Remove the old cables from the twist grip. Reinstall new cables in the reverse procedure. Before starting the bike, make absolutely sure that the throttle cables work like they're supposed to and the carb/throttle body will close completely.
To remove the clutch cable, remove exhaust system or whatever might be in the way on the right side of the bike. You need to remove the right side transmission cover. Drain the transmission oil. Remove the chrome right side transmission cover. Disconnect the clutch cable from the clutch release mechanism. Screw the end of the clutch cable out of the cover and take the cable loose from the clutch lever on the handlebars. Reinstall in reverse order making sure you install a new O-ring on the cable at the transmission cover. Replace cover and refill transmission with oil. Reinstall anything else you had to take off.
Feb 15, 2010 | 2008 Harley Davidson FLHR Road king
Clutch cable leeks oil
The o-ring around the threaded end where it enters the transmission only keeps the oil from leaking to the outside. If you're getting oil on the inside of your cable, the cable needs replacing. The small oil seal is in the end of the threaded piece that screws into the transmission end cover.
Oct 19, 2009 | 2005 Harley Davidson FLHT - FLHTI Electra...
Loss of acceleration. Transmission? Clutch? Cable?
The cable you are refering to should not be slack or, come off tighten it and, secure it also; check the transmission shift cable
May 29, 2009 | 1983 Volkswagen Rabbit Pickup
Garden Logo
52 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
