Question about Ovens
C970-657231 range
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Frigidaire electric oven digital display not coming on
Good Afternoon Friend, I am happy to assist you!
Based on the symptoms you are describing it sounds like your range could possibly be experiencing a communication problem with the EOC (Electronic Oven Control) or a potential wiring failure. Let's try resetting your range by either flipping the household circuit breaker to the off position or by unplugging it. It is best to wait approximately ten minutes and then turn on your range. If resetting the power to the range does not correct the issue, at this moment I would personally contact a professional to accurately diagnose your range to determine the root cause to reduce the risk of unnecessary parts.
Best regards! - Z
Jul 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
This message is displayed on my oven: EO - F2 - What does it mean?
E0 F2 fault code usually indicates a shorted touchpad on the oven control. Firs disconnect power to the range for 30 seconds and restore it. This will cause the electronic range control to reset and sometimes will clean errors.
If the error returns the touchpad on the control will have to be replaced. Some ranges have the touchpad made on the control and the oven control has to be replaced.
Open the drawer under the oven and look on the frame of the range around the opening the drawer slides into for a model number tag. Get the model number of the range and go to searspartsdirect and you can see a parts diagram and list for your range.
Hope this helps.
Sep 21, 2011 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not coming on/heating up although top plates are working
If the burners are heating up but seem to take along time to get up to heat and your oven doesn't seem to be working you may have only 115 volts of power going to the range rather than the full 240 volts that are needed to power up the bake/broil oven elements.Check circuit breaker(s),check range receptacle behind the range for 240 volts,check for full power at the terminal block on the back of the range where the cord connects to the range.Good luck!
Nov 22, 2009 | Smeg Ovens
Replace clock on range
there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Control panel Roper gas range replace or buy new range?
4337979 Control-Clock/Oven
Retails for $206.90 easy to replace good luck..
Sep 28, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
