Question about GE Monogram ZDI15C Automatic Icemaker
Ice maker wont come out of clean
Worked yesterday, tried unpluggind unit, time out , powered up, still in clean cycle
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Posted on Sep 02, 2007
  • 464 Answers
SOURCE: ice maker makes ice really slowly
perhaps there is not enough water being brought to the ice maker from the inlet valve. you may have to change the valve.
Posted on Oct 24, 2009
heatman101
  • 43501 Answers
SOURCE: Unit is 15 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Ice maker is cycling water through every 15- 30 mins but not freezing.
see if unit getting hot on back if not electric or LP bad cooling unit or board
May 09, 2014 | Dometic Portable Ice Maker HZB-15S
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
U-line CLR2160 won't go into clean cycle. I hold the power button while pressing the light button 3 times.
I had to hold Power for 10+ seconds (until last "F" flashes, quickly let go of Power, then press and hold it again and while holding it pres the light three times.
The process doesn't follow the manual's instructions at all.
Their older model units with the physical on/off/clean selector switch was much more reliable than their new 2160 with touch screen controls!
Nov 20, 2011 | U-Line Icemaker
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
My icemaker will get cold but wont make ice.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
GE Monogram ZDI15C Automatic Icemaker Logo
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
