Question about Vizio Televison & Video
Debug message on tv - Vizio Televison & Video
My projection tv says "debug" on the screen what do I do?
Are you sure the message is coming from the TV or could it be comming from a component you have connected to the TV?
Mar 15, 2014 | Mitsubishi WD Televison & Video
Debug message on far side of Screen
Firmware corrupted. Contact the authorized service center.
Gopakumar Gopalan Google
Mar 04, 2014 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • Oct 25, 2011 | Microsoft Windows XP Professional
    We are getting an Internet Explorer Debug message and Windows Explorer Debug message when trying to access the Internet.
    explorer gone bad, you need to upgrade windows explorer or install some other browser like opra, chrome or fire fox
    Nov 05, 2010 | Computers & Internet
    What does debug mean , it stops me from doing anything .
    Just click no. This message is intended for the people that created the application.
    May 07, 2010 | Yahoo Mail
    Media Center for Window XP, TV don't work.
    Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
    Nov 02, 2009 | Microsoft Windows XP Home Edition
    DeBug appears whenever
    what IE are you using?
    the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
    Mar 27, 2009 | Microsoft Windows 2000 for PC
    I downloaded updates and now I'm getting "runtime error" messages
    Turn off the Machine Debug Manager Service. It is only needed if you are debugging Visual Basic software.
    To do so:
    1. Click START, select RUN
    2. Type "Services.msc"
    3. When the Management Console opens, search for "Machine Debug Manager" on the right hand panel and doubleclick on it to open it's property sheet
    4. On the property sheet, on the "Service Status",click "STOP". On the "Startup type:" select Disable (or Manual)
    5. Close the Property sheet; Exit the Management Console
    You may need to reboot the pc.
    I recommend a program named Autorun from SYSTERNAL to control what runs on a PC.
    Dec 12, 2008 | Microsoft Office 2003 Basic Edition...
    JIT debugging
    Dear rmakrishnan2,
    JIT stands for Just In Time and I believe it's some sort of compiler and sounds like your .NET infrastructure may need to to be reinstalled. Try the Add/Remove programs control panel to Repair or Reinstall your .NET infrastructure.
    Jul 29, 2008 | IBM ThinkPad T30 2366 Notebook
    Catalyst driver
    You should always choose the newest one. There is no reason it should not work. Try updateing all your programs and drivers.
    May 29, 2008 | Computers & Internet
    Televison & Video Logo
    11 people viewed this question
    Top Vizio Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
