Question about Gilmour W4 Spray Doc 4 Gallon Wheel Pump Sprayer
Need part w2fltdp for wheel pump by Gilmore where can I buy 1
Where can I buy part
How do I install Gilmore gears into 304 v8
I think you are talking about a Gilmer drive which is a toothed drive belt. You need the correct kit to suit your motor, then you remove the crank, water pump and alternator pulleys. Theses are then replaced with the alloy Gilmer crank and water pump pulleys. The alternator pulley is steel and all these pulleys are smaller than the stock pulleys. Be prepared to replace the crank and water pump pulleys for they ware out faster than the belts do.
Dec 29, 2014 | Holden VT Cars & Trucks
It will not spray
Your pump cam follower may be broken, such that the pump is just not working. Good news, you don't need to buy any new parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmour provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business. Since the higher the wheel speed the more stress there is on these tabs, I would not recommend moving the wheels any faster than what occurs with a slow walk.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
Jun 04, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
The camera dont make pictures no more, the zoom dont react and the stored pictures are not to show anymore. Here in Butuan City, Philippines no one is able to find out whats wrong. I buyed the camera in...
The only license service center here in the philippines is in
Servimax Technologies Inc.
Unit G Gilmore Commercial Plaza #10 Gilmore Avenue,, New Manila, Barangay Valencia, Quezon City, M. M. 1112 Philippines
Tel :(632) 721-9102, (632) 722-2992
Fax :(632) 721-6819
Jan 10, 2011 | Olympus Camedia C-700 Ultra Zoom Digital...
I f u can give us service center her in manila thank you
ASUS Philippine Call Hotline:1800-1441-0573 (10:00-21:00 Mon. ~ Fri.)
Please call:+63-(2)-636-8504 if you use mobile phone.
Asusworld Megamall
+63-(2)-6382955 (10:00-22:00 Mon. ~ Sun.)
SM Megamall 4th Floor Cyberzone Bldg. B Mandaluyong City
Tekzone Makati
+63-(2)-8128976 (08:00-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
7185 Export Ave. corner Chino Roces Makati City
Tekzone Cebu
+63-(032)-4227510 (08:30-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
E-14 J Kings Warehouse Complex Hernan Cortes Mandaue City
Servimax Technologies Inc.,
Unit G, Gilmore Commercial Plaza
#10 Gilmore Avenue, New Manila Quezon City
Phone: (+632) 721-9102 and 722-2992
Fax: (+632) 721-6819
Schedule 10:00 - 19:00 Monday to Saturday
ASUSWorld Virra Mall
4th Level VMALL Plaza Greenhills, San Juan, MM
Phone:+632 584-2612
Schedule 10:00AM - 20:00PM Monday-Sunday
AW Gilmore Zone
3/F Gilmore IT Center Bldg., #8 Gilmore Ave., cor. 1st Street, New Manila, Quezon City
Phone:+632 994-3696
Schedule 10:00AM - 19:00PM Monday-Sunday
SUWERTE,
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | ASUS Computers & Internet
My new sprayer will not pick up the solution.
Terry - I did the same thing and am frustrated. Anxious to see the answer. I have tried "backflushing" per instructions, and running yardtrimmer line up the nozzle to check for debris.
Siphon just does not work. Even with clear water.
May 26, 2010 | Garden
Where can i find the best place to buy computer parts in the philippines?
Go to gilmore in quezon city. That's the best place you can get pc parts.
Feb 14, 2010 | HP Pavilion dv6000z Notebook
Bugaboo gecko tire flat and tube no longer attached to wheel
First try pushing the valve out while your pumping with bugaboo pump. If it blew out need to call bugaboo you have a two year warranty and they will send you a inner tube or a new wheel.
Tel# 1-800-460-2922
nathalie
Dec 04, 2008 | Bugaboo Cameleon Jogger
Location
Hey Annieaussie,
Currently Best Buy™ stores are only located in three countries: the United States, Canada, and China. As a result, the vast majority of DVD's and DVD boxed set that are sold through our stores and each country's respective website will be either Region 1 (U.S. and Canada) or Region 6 (China).
Unfortunately, Best Buy™ stores are not able to custom order DVD's from different regions and cannot ship internationally at this time.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 22, 2008 | Audio Players & Recorders
Gilmour W4 Spray Doc 4 Gallon Wheel Pump Sprayer Logo
75 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
