Question about Tomtom GO 630 Car GPS Receiver
Problems with rear connector on tomtom go60
Power connector loose
Traffic RDS for Tom Tom Go60
Only as an additional purchase.
Its a charger with traffic built in, cost around 50.00 and I would not bother. Why you say
Next year most of the UK's analogue radio signals will be turned OFF. Then you have to use 'Digital Radio'.. I'll give you 2 guesses as too what is NOT digital compatible. Save your money and wait for the digi version
Mar 01, 2014 | GPS
All rear lifgate power not working. camera, rear windshield wiper and rear window
Check fuses. Check connectors, I had a power outage in the rear of a honda accord and found a connector loose in the rear wiring by the brake lights area.
Oct 04, 2013 | 2008 Jeep Grand Cherokee
2004 Maxima - The rear window defroster used to only come on once the car warmed up. Now it won't come on at all. Any sugestion on how to fix this or what could be wrong? Thanks
Hi Sabe, I'm glad to help!
First go to the rear window glass and check power and ground at the glass connectors, also make sure they are connected to the grid because if they are loose then you have found the problem. If they are tight and you have no power to the connector then check fuses. If the fuses are good you'll need to find out why your loosing power between the fuse and the rear glass connector. It could be another connector somewhere in between. Hope this helps and have an awesome day Sabe.
Jan 25, 2013 | Nissan Maxima Cars & Trucks
Hello 2006 Kia Rear defroster does ot work. I checked and changed the fuse but the fuse looked ok. Any help as to where to look for the problem would be appreciated. Thankyou, larry
It could be a bad rear defroster control switch or relay, it could be a loose or damaged connector somewhere in the defroster circuit, or it could be a damaged or defective defroster grid on your rear window. The easiest way to check to see if you have a circuit problem or a grid problem is to check for voltage at the connectors to the defroster grid at the rear window area. These connectors may even be located inside the trunk just below the rear window. If there is power there, then the circuits are OK and the rear window will most likely have to be replaced to fix it. If there is no power there, then the circuits must be traced to locate the cause of the failure...Most likely a burned-up switch and/or connector.
Jan 22, 2011 | Kia Sportage Cars & Trucks
My computer will not acknowledge my tomtom go 720 is plugged in to usb connector power light is on in charging cradle but computer says not connected
I had the same problem. I tried uninstalling software and re-installing it. That did not help. I reset my TomTom Go 720 with the reset button on the bottom of the unit. The computer then recognized my TomTom.
Aug 30, 2009 | Tomtom GO 720 GPS Receiver
I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Mar 30, 2009 | Tomtom One XL GPS Receiver
Lack of Battery
First make sure it is your battery. Check to see if when you are charging your device and wiggle the USB cable a little if the green charge light starts blinking. If it starts blinking on and off you have a loose USB connector. This is an easy fix if you have some soldering skills. Your device should not turn off when it is hooked up to power even if you have a dead battery.
Jan 29, 2009 | Tomtom ONE GPS Receiver
Tom tom one v1 Loose power connector
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
Jan 26, 2009 | Tomtom ONE GPS Receiver
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 630 Car GPS Receiver Logo
11 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
