Question about Philips Audio Players & Recorders
Philips streamium wacs7500 stuck in stand by
Stuck in stand by mode flashing red
issy2
  • 462 Answers
SOURCE: PROLEM RIPPING CD ON MY STREAMIUM WACS7500
Software not supported...!!!
Posted on Jun 17, 2008
mistersony
  • 320 Answers
SOURCE: Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Posted on Oct 19, 2008
skotkolr
  • 558 Answers
SOURCE: ITS STUCK IN STAND BY MODE
inside the unit is a power pack assemble three capacitors in between two smaller heat sinks have popped, they can be replaced and the unit should power up just fine. they are 16 volts at 1000 uF.
Hope this helps,
let me know
Posted on Apr 05, 2009
projdoc
  • 2237 Answers
SOURCE: wacs7500 streamium cannot read discs
remove the cover and gently clean the lens with a q-tip dipped in rubbing alcohol, then blow the lens dry. if all else fails, replace the optical pickup assembly (lens and spindle motor) or the whole player.
Posted on Jan 29, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Philips Streamium
The manual is here.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=WACS7500/05&scy=gb&slg=en
The answer is here in the FAQ's. It does not support gapless playback.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&mid=Link_FAQs&view=aa12_view_partial.html&session=20110421112404_68.229.77.231&list=aa12_list_partial.html&slg=ENG&ctn=WACS7500/05&dct=FAQ&refnr=0074187&faqview=1
I imagine if it was a current product and enough users complained to Philips a 'fix' might appear.
Posted on Apr 21, 2011
Philips WACS7500 switched on and stuck in standby modee. Power light flashing red. Do you know how to reset to normal switch on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Dec 25, 2017 | Philips Televison & Video
My WACS 57 Center will not ever boot. It just always says booting up. What can I do?
contact the manufacturer through the suppoet facility on their website, they are the best people to help you in this matter and may ask you to return the item dor inspection/repair/replacement. This is not the forum for your particular problem I think.
Jun 15, 2015 | Philips wacs7500 streamium 80gb wireless...
WACS7500 HDD partition
U can create a total of 4 physical partions on any disk...
U can then create total3 primary and multiple extended ones
What exactly is u need depends on what purpose the computer system is for
Oct 25, 2014 | Philips WACS7500/05 Shelf System
What to do with red blinking ON/OFF button on philips mci500h 12
Internal Power supply and could be a shorted diode or a relay could be causing the flashing red light. Usually the red light indicates the System is in stand-by mode or not in stand-by. If when you used to turn it off there was a red light though not flashing, then that means it is in stand-by so in that mode your remote works on some older sets work and others it doesn't matter because the remote will always work. Unplug it for a half hour and try it and see if the light stops flashing. Might help to give more clues towards the fix.
May 15, 2014 | Televison & Video
Philips Streamium WACS7500 STAYS ON CAN NOT USE
It is difficult to determine how much to repair because the computer needs a detailed check/test. Your computer repair shop can give you a quote.
Oct 08, 2012 | Computers & Internet
Wacs7500 streamium cannot read discs, just says 'no disc' or cannot read disc. have tried a cd lens cleaner with no success
Jan 28, 2010 | Philips Audio Players & Recorders
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
