Question about Vehicle Parts & Accessories
'93 D150 starter relay location
Need to replace
    Sergeant:
  • 462 Answers
Usually mounted on inner drivers fender
Posted on Sep 07, 2014
Fix starter on a 93 nissin P.U.
I have replaced the starter and the relay and I still don't get the starter to start I have checked the switch on the cluch to see if that was the problem and it seems to be working fine. What else could it be ????
Doug
Apr 16, 2013 | 1993 Nissan Pickup
93 dodge caravan ignition system schematic
Your saying you replaced the ignition switch, and a new starter relay, The 93 always has problem with the nuetral safety switch or what is known as the PRNDL,you will find it facing the front of the vehicle on the transmission, make sure the connection did not come off,11_24_2012_2_30_20_am.gif
Nov 24, 2012 | Dodge Caravan Cars & Trucks
I have a 93 caddy deville 4.9 that wont start i have replaced the starter and when that didnt work i thought must be a bad vat switch so it was changed still no luck im getting 12 volts power to the...
The starter's mechanical 'relay' on a 90's caddy it attached to the starter, it is the solnoid and may be defective. Check your connections and harnesses for the smaller wires going to the solinoid. There probably is a standard electrical relay under the hood in the power distribution center, and it should be marked either in the owners manual or the top of the center lid itself. You can swap it out with another standard relay not needed like your ABS or horn relay to see of this is the problem.
Mar 22, 2011 | 1993 Cadillac DeVille
91 Dodge D150 P/U. Want to change fuel pump relay. 3 relays in a row that all look the same between starter relay and brake booster. What are these and which one is the fuel pump relay?
fuel pump relay should be marked in cap o black box cover,flip cover of box upside down to read location of relay,,one is a/c relay other fuel pump relay @ other is starter relay.. hope this helps!!!
Aug 16, 2010 | 1991 Dodge D150
My Dodge 1985 d150 won't start. New starte,
if you hear a loud click from starter it could be the motor contacts in the starter have gone bad. you will have to remove starter and have it repaired or replaced. check again to make sure that the battery is charged up on truck. also check for a loose ground wire to starter or engine block.
Apr 26, 2010 | 1985 Dodge Pickup 4WD
Where is the starter relay located? 93 plymouth grand voyger 3.3L New starter,but just clicks, will start after many tries.
Check drivers fender area, under hood, near strut mount. You should be able to hear and feel click in one of those relays. Check part #'s on them, they are usually same for 2 or 3, which allows you to use another to test circuit before replacing so you know.
Nov 25, 2009 | 1993 Plymouth Grand Voyager
I have 1992 Dodge D150 with 318 magnum. It won't
is this vehicle fitted with a chipped key ?? iam thinking factory immobilisor here?? but not sure what year it was introduced in america
Nov 22, 2009 | 1993 Dodge D150
I have a 1988 Dodge D150 I am getting NO power to the starter.
Try you earth lead from the battery make sure its clean.Where it joins the engine and chassis
May 30, 2009 | 1989 Dodge D150
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
